07-22-2014, 05:59 PM | #1 |
Rep 623
Another option for coolant/boost/etc gauges
I ordered the a WiFi ELM327 OBD2 reader ($20 http://www.amazon.com/gp/product/B00AOIM2CC) and bought the ODB Fusion app ($10) for my phone on the App store and am very impressed with the capability. It has a ton of different items that can be monitored and while it most likely the app won't always be on like a permanent gauge, I don't know if these numbers really need to be known 100% of the time. I assume the OBD2 scanner can be left plugged in all the time, right? For $30 I think it's well worth it.
07-22-2014, 06:44 PM | #2 |
Rep 835
Great idea especially with the phone mounted like that. Does the phone stay in place under hard driving?
2020 X3M Comp., Alpine White on Black/Beige
RETIRED: 2018 440xi GC, Carbon Black on Black/Blue 2014 M235i Black on Black, DINAN Stage 2 |
07-22-2014, 07:22 PM | #5 |
***** noob
1369
Rep 10,479
Sorry to thread jack
I just spoke to Rick @ p3cars and they will have a new version of the p3 gauage with oil temp within 2 weeks...not sure how reliable this is but Im going to wait for that
2006 325xi (Sold)
07-22-2014, 07:47 PM | #6 |
Rep 439
FYI, if you drive your car every day it's safe to leave the dongle plugged in, but it does draw constant power, so at some point of non-use of your car it will drain the battery to the point where it won't start.
There was a kickstarter a while back that was for an ELM compatible OBDII wifi dongle that will auto shutoff to not drain battery, but it's $100. And yes, OBD Fusion is great. Here is my custom screen tailored for our cars that don't have temp gauges.
2014 981 Cayman S 6MT, X73 Suspension, SES 2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i |
07-22-2014, 08:13 PM | #7 |
Rep 623
That looks great!
I'm surprised it doesn't have an oil temp readout, but apparently the P3 doesn't either right now? Weird because it's one of the Secret Menu items right? So the value is there somewhere. @Jerich0: It does read (and I assume clear) codes. Here are some more screenshots from a drive I just did. Car idling at stop light: Driving at 60 MPH: Codes: All the different monitored sensor options: [img]http://s27.postimg.org/4rijgi58z/image.jpg[img] |
07-22-2014, 08:16 PM | #8 | |
Rep 623
Do you know if theres a setting for the app to show max reading for each particular sensor? Seems that should be an included feature but it's not on by default. |
07-22-2014, 08:21 PM | #9 |
Rep 439
Yes, you can manually set the range for any display, select the display and then select Display Configuration.
EDIT: after re-reading your question, I think you are asking if there is a 'sticky' needle that displays the highest reading reached in a certain amount of time? I haven't been able to find one, but I agree it's really something they should have. For now our only real option is to download the log file and find the peak values there.
07-22-2014, 08:25 PM | #10 |
Rep 623
Sorry wasn't clear...I meant will it show the max value recorded? Like if you floor it, will it show the max value of the Boost etc without you having to actually look at the the phone?
07-23-2014, 10:58 AM | #11 |
Rep 269
Torque Pro for Android does. There's a little tick mark on each gauge that records the max value.
07-23-2014, 11:03 AM | #12 |
Rep 623
BLAH! Why can't they have an iPhone app?
I emailed the guys at OBD Fusion and they said their app does not support that, but will add it to a wish list for a future update. Would be really useful if you're doing testing, you don't want to sit there staring at the gauge while trying to drive. |
