02-09-2019, 04:56 PM | #1 |
Rep 1,290
coding questions
I recently got the bimmercode app and veepeak adapter. I tried some coding today on my 2019 M240i and had a few questions I was hoping someone could answer.
1-Where in the bimmercode app do I go to clear a check engine light? 2-How do I activate the rear fogs? I modified the switch already and I found something in the bimmercode app about monitoring the voltage of the rear fogs but no option to turn them on. 3-I coded the mirrors to fold when I lock the car through comfort access but couldn't find a way to do it with the fob too. Is this possible? thanks in advance for answers to these questions! |
02-10-2019, 07:56 AM | #2 | |
Rep 278
See above in red |
mblaucoupe135286.50 |
02-10-2019, 08:06 AM | #3 | ||
Rep 1,290
02-10-2019, 08:32 AM | #4 |
Rep 278
Yes, I believe its iphone only. I only have bimmercode. Never looked into bimmerlink.
This is a good comparison below https://elm327scantool.wordpress.com...carly-bmw-app/ |
02-10-2019, 09:06 AM | #5 | |
Rep 1,290
02-12-2019, 07:54 AM | #6 |
Rep 278
03-17-2019, 05:43 AM | #8 |
Rep 1,271
You can try OBDFusion for your smartphone or tablet. Then go to E46Fanatics and search for threads OBDFusion in which jfoj has commented. He’s the guru. It’s a very capable app. I’ve used it for years on my E46 and on my F22. Done leave home without it.
03-20-2019, 12:15 AM | #9 |
Rep 134
so you have retrofitted the front foglamp but only need help in coding section? i can help you
Instagram: @tafikhulafaa & @88tuning.id
03-20-2019, 08:23 PM | #10 |
Rep 6
Hi, I bought my f22 14", it was crashed and i am wondering if i can code/remove Active Pedestrian System. I am missing two sensors on the front bumper and they are expensive to replace so... I saw on the forums you can remove this option called 8TF on BMW f10.
03-23-2019, 05:12 AM | #11 | |
Rep 134
are you familiar with esys and VO coding? if not, feel free to ask me abt the details. T
axtross960.00 |
03-24-2019, 11:43 PM | #13 | |
Rep 134
And please note that you have to use esys in order to do VO Coding. T
axtross960.00 |
03-29-2019, 01:39 AM | #15 | |
Rep 134
T
axtross960.00 |
03-31-2019, 06:28 AM | #16 |
Rep 6
Hey I redid everything once again and cleared all errors with E-Sys. Now everything works perfect. I don't anymore have Pedestrian warning, and iDrive shows RFT instead TPMS. Thanks guys very much, cheers.
EDIT: I noticed i cannot turn the ventilation off now. I can regulate it and all, but cannot turn it off. Last edited by axtross96; 03-31-2019 at 08:14 AM.. |
