04-10-2020, 11:06 AM | #1 |
Rep 85
Cruise control issues and Start button
Hello all,
Reposting question in General Forum: 2015 F23 M235i, premium. Coding using Bimmercode. I have made several changes over a month or so and all going well. Love all the specific control over our features. The last coding I did was adjusting the timing on the delay for the windows, convertible, etc when using the remote and door handle to lock/unlock. Was trying to make the top not start raising when I just wanted to lock and mirrors to fold. After the coding I have two problems: Cruise control will not activate. (I just have the standard cruise, not distance control. Just a message under the speedo that it won't activate. also: When I hit the start button with no foot on the brake, the car now starts. There is no, car is "on" but not running. Search on the forum, indicates that it may be due to a few ECUs not being in sync. Tonight I tried to code, making a change in most of the ECUs (KOMBI and FEM? Again, using Bimmercode in standard mode.) and saving. No joy, still the same errors. I am using Bimmercode Android, and tried doing a FEM restore, no joy. I don't see where you can go back to specific dated backup codes, as mentioned on Bimmercode website. Any thoughts? Thanks in advance for your time. |
04-10-2020, 11:43 AM | #2 |
Rep 85
Bimmercode
Going to try this:
FEM_BODY 3020 TCM_STARTLOCK_BRAKE nicht_aktiv aktiv Start Car without holding brake pedal down. FEM_BODY 3020 TCM_STARTLOCK_CLUTCH nicht_aktiv aktiv Start Car without holding clutch pedal down. FEM_BODY 3020 TCM_STARTLOCK_DRIVINGREADINESS nicht_aktiv aktiv Start Car without holding brake or clutch pedal down I haven't coded anything in expert mode, so hoping for the best (and doing research.) |
