2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Steering malfunction
      09-07-2015, 10:14 PM   #1
2msport
Drives: '14 228 MT
Hey guys, well it's a sad and inconvenient day. I just finished a nice weekend up in the mountains and literally as I went to start the car to leave I get a "steering malfunction". It's very hard to turn the wheel and feels as if there is no power steering at all. IDrive says to drive moderately and to contact a service center. The drive train works just fine as I'm able to move forward and reverse. When power steering goes out I understand the faster you drive the easier it is to turn the wheel. Unfortunately it's a little too risky to get down the mountain and I don't want to make the situation worse.. My car is being towed to the nearest bmw, which isn't close. Any insight on this? Fuse to be reset? Wish me luck
Edit: I have variable steering with adaptive suspension
      09-08-2015, 08:02 AM   #2
JMatt88
Drives: M235i XDrive
WOW, first time I've heard of this one. BMW will likely make it a priority investigation. Can't have that happening at 80mph on the highway !
      09-08-2015, 09:14 AM   #3
Merc for hire
Merc for hire's Avatar
Drives: M235i 6MT
Wow power steering failure.
I had this happen once in my old e46. The hydraulic power steering pump shaft broke in half!
Fortunately these type of failures usually happened at low speeds when the required turning effort is at its highest.
      09-08-2015, 09:27 AM   #4
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
The only thing I would suggest is trying to see if the power steering reservoir is still full. Could possibly be a leaking hose or crack. Had this happen on my Acura.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      09-08-2015, 09:36 AM   #5
Merc for hire
Drives: M235i 6MT
F22 uses electric power steering. No fluid.
      09-08-2015, 10:17 AM   #6
scrape1
Drives: '14 228i M Sport, '04 X3 3.0i
Pretty sure it happened to a C/D long term 328i a few years back. They said the dealer replaced the entire steering rack, and that out of warranty, a new rack runs around $3500 plus installation. Doesn't seem to be a common problem, but if you are unlucky enough to have this happen out of warranty, it's going to be an expensive one.
      09-08-2015, 01:45 PM   #7
2msport
Drives: '14 228 MT
Well I have good news and bad news. The good news is it wasn't a BMW reliability issue. A rodent chewed through about 3 wires. The bad news is it's not covered by warranty. It's an outside influence. Make sense but it's still $300 out of pocket. I'm just happy to get my car back pretty quickly.
Thanks for the comments
      09-08-2015, 02:24 PM   #8
Cyberdemon
Cyberdemon's Avatar
1538
I knew this. (Need to stop writing things before I've had my morning coffee).
*facepalm*
Tags
hard to turn wheel, steering malfunction
