2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Exhaust rattle post muffler delete
      04-09-2024, 03:16 AM   #1
jurassic_h3
Drives: 2017 BMW 230i
Hi everyone,
I had gotten a muffler delete on my 2017 BMW 230i and since then it has a rattle from what i can tell is the OEM valve during a cold start until the car is warmed
I’ve done research and found that the actuator clip could be the culprit, but i checked and the actuator clip seems to still be there.
Two questions i have are:
will going to BMW and having the rattle checked out cause any warranty issues?
is there any fix to this problem? i tried opening the valve and unplugging it and drove around a bit but the rattling got worse so i plugged the actuator back in.
thanks so much!
      04-09-2024, 04:21 PM   #2
Shirazkhan
No_Country
28
Drives: bmw
Bmw might void your warranty because you did the muffler delete.But if you good with the dealer then go ahead.
