M Performance diffuser+ intermediate pipes+ BMS tips+ stock exhaust |
04-13-2018, 02:04 PM | #1 |
Rep 16
In regards to upgrading to M Performance diffuser on the F22;
I think I`ve gathered that you would need to cut the stock exhaust 120mm from back end, to fit the needed intermediate pipes/ adapters extenders, part# 18302287042, for correct and alignement. Does the BMS slip-on 3.5" tips fit the intermediate pipe? Can anyone who have done this verify the information above? Last edited by Finkel; 04-14-2018 at 04:27 AM.. |
05-18-2018, 04:13 PM | #2 | |
Rep 138
05-20-2018, 01:04 PM | #3 |
Rep 16
BMS 3.5" tips does not fit the intermediate pipes, the springs inside the tips will not hold and you will most probably ruin them, as I ruined mine and had to throw away the BMS tips.
The stock tips fit the intermedate tips though, and I had to use these as a temporary solution until I find some tips that will with the intermeidate tips. |
05-21-2018, 11:37 PM | #4 |
Rep 1,078
I wonder if the extender is the same diameter as a stock M-performance exhaust, which I know doesn't fit BMS tips. I do find it strange that the stock exhaust tips works on both the extender and the M-performance exhaust, but the BMS tips don't.
05-22-2018, 01:47 AM | #5 |
Rep 5,366
I'm running BMS tips on my MP exhaust, no extender pipes. No issues fitting the tips. They were tight to fit but I got them on with some squeezing to the tabs with a screwdriver.
05-25-2018, 06:48 AM | #6 | |
Rep 138
