02-06-2018, 05:07 PM | #23 |
Rep 225
$600 Just for the license + $300 OBD agent + $20 cable + $50 per map means you're looking at nearly $1000 assuming you want to take advantage of every feature the BM3 has to offer... Hardly cheap
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
02-06-2018, 10:42 PM | #24 |
Rep 97
02-06-2018, 11:34 PM | #25 |
Rep 225
No, I believe the agent is just for changing features/maps with the phone app. Unlocking is done via the ENET cable
02-09-2018, 03:41 PM | #27 |
Rep 190,597
I would like to share this message that i just got from one of our customers
FYI - M235i owners need this tune! This tune will be giving M cars a run for their money, as long as they do not have one as well haha. What a difference a flash tune from AA makes, and it stacks with the Dinantronics Sport boost controller!!!! 17.5 psi stock flash. 21.5 psi on 93~95 octane using "Race" mode on the Dinantronics Sport (sport 18.5psi, sport+ 19.5). Data logging with BlueDriver just in case anything looks out of balance, but a lot smoother than the factory tune. Butt Dyno is telling me 400WHP, but I will get this on a dyno soon to further prove the gains
ceedawg467.50 |
02-09-2018, 05:45 PM | #28 | |
Rep 555
JP's M2xx20.00 |
02-09-2018, 05:47 PM | #29 | |
Rep 190,597
I stack tunes on all my bmws, my piggy of choice would be Jb4 since it has additional failsafes to protect yourengine if anything goes wrong
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 02-09-2018 at 09:16 PM.. |
02-09-2018, 08:54 PM | #30 |
Rep 1,931
Been doing it for 2 years, no issues. Know what your doing like anything in life...
www.nybmwcca.org
02-09-2018, 11:45 PM | #31 | ||
Rep 225
BM3 is so far the best ROI of all my mods.
18 340i F30 mostly stock |
FSociety3811.50 |
02-10-2018, 02:56 AM | #32 |
Rep 225
Could someone enlighten me - what are the benefits of stacking tunes? I was originally going to sell my JB4 once I got the flash.
02-10-2018, 08:37 AM | #33 | |
Rep 225
Presently I am having some issues as the JB4 seems only able to simulate ~19.2 PSI to the DME, so if the flash tune has any boost targets higher than that the DME wont be able to control the boost correctly. Another reason would be easy map switching depending on fuel. The example Mike posted above is good. If the boost is too high for the fuel and the DME detects knock it pulls the timing / boost back significantly. Something to avoid for sure.
18 340i F30 mostly stock Last edited by M235SDCA; 02-10-2018 at 08:43 AM.. |
02-11-2018, 07:02 PM | #36 |
Rep 2,214
For those who don't understand the reasons for stacking, here's my standpoint.
I already own a JB4, and got it cheap. I plan to "stack" it for boost control (above and beyond what the flash tune offers), and Meth control, which the tune does not offer as of yet. I already have Meth installed, and the JB4 gives me full monitoring and control of the system via cell phone infrastructure (live data, boost controller, data logger, map changer, etc) on the mobile app. Has to be one of the most convenient systems I've ever used. Adding a flash tune greatly enhances the baseline DME programming, something the JB4 simply can't accomplish on its own. Combined, I feel it's a very strong combination to have.
ceedawg467.50 |
02-12-2018, 09:53 AM | #37 | |
Rep 1,541
02-12-2018, 01:35 PM | #38 |
Rep 146
Will the BM3 tune require mechanical upgrades such as charge pipes and downpipes? Is there a chance of blowing up the OEM parts?
2015 ///M235iX | Mineral Grey | Dakota Black | Premium | Tech | Cold | Driver Ast | HK Sound | Black Kidney Grilles | M-Performance Exhaust | Front Splitter | Carbon Fiber Mirror Caps, Rear Spoiler and Exhaust Finishers
02-12-2018, 01:38 PM | #39 | |
Rep 190,597
Charge pipe is needed with any tune and any map
02-14-2018, 10:56 AM | #40 |
3441
Rep 79,212
You'll always want to upgrade your charge pipe on this platform with any tune, they are notorious for cracking, even under stock boost but especially when boost is increased with a tune.
02-21-2018, 11:30 AM | #41 |
Rep 26
I have the stock cat on and i am pushing well over 430 whp. I am switching to a 3.5 bar adapter and AA is making an updated map for stock cat and my AR Design catted DP, because I am maxed out on boost (attached) 21psi+. Logging data, everything looks normal. 5th gear spins wheels when downshifting at WOT. 0-60mph runs are tricky or else it is all wheel spin all the way through 4th gear on PSS tires. I hope AA makes a data logging OBD2 tool with map selection functionality, otherwise this combo of mods is working damn well for me. Highly recommended!
ceedawg467.50 |
02-21-2018, 01:01 PM | #42 | |
Rep 1,184
02-21-2018, 01:09 PM | #43 |
Rep 26
Stock turbo, 91 pump gas with octane boosted to 95, no meth. AA's Simon3 is no joke. I am installing the 3.5 bar adapter today and loading the first stage 1 update for the new sensor and see what the results are. I'll log to make sure everything is fine and if so, I'll flash a modified version of stage 1 with slightly higher boost targets. I am experimenting for AA and will get back to them tomorrow with the results. If the increased boost logs normal, they will update the enhanced 3.5 bar stage 2 flash to accommodate the ceramic coated AR catted DP being installed on Saturday. I am hoping for 475 whp on stock turbo.
02-21-2018, 02:03 PM | #44 | |
Rep 647
http://www.2addicts.com/forums/showthread.php?t=1455885 |
