05-11-2014, 06:36 AM | #1 |
Rep 62
M performance gear knob
Tdkbabab in another thread stated that "...fit the M performance gear knob shortens and improves the shift hugely (in my opinion)"
Does anyone have any experience/comments about the M performance gear knob? THANKS! Last edited by math4scher; 05-11-2014 at 07:02 AM.. |
05-11-2014, 07:57 AM | #2 |
Rep 1,178
It shortens the length of the shifter, and it is slightly heavier. These make it an improvement over the stock shift knob. So, the answer is Yes. Don't buy it from BMW for full retail price, you can get it from a fraction of the cost from an aftermarket supplier or maybe getbmwparts.com
05-11-2014, 08:45 AM | #3 |
Rep 3,071
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
05-11-2014, 04:03 PM | #5 |
Rep 62
What does the one you bought look like? Is that the same one made of carbon fiber? Where do you get/buy that? Is it part of a package? Is it a stand alone option? Is it an after market purchase? THANKS for your sharing!
05-11-2014, 04:41 PM | #6 |
Rep 97
Drives: BMW E30 M3, BMW X3, BMW 540i
Here's the BMW M Performance Carbon Fiber Gear Shift Knob with Alcantara Boot. It will fit the 228i and M235i, assuming of course you have MT
Part No. 25-11-2-222-529 You can purchase it from any BMW Dealership or a multitude of websites including ebay and Amazon
Cheers,
Steve |
05-11-2014, 05:09 PM | #7 | |
Rep 62
Thanks for sharing the picture/info, but do you know if it really makes for shorter/more precise shifts - thanks! |
05-11-2014, 06:48 PM | #8 |
Rep 97
I don't have personal experience with the manual transmission, but reading other threads in these forums have only offered positive reviews of the shifter, both in throw and feel.
Cheers,
Steve |
05-11-2014, 07:14 PM | #9 |
Rep 62
05-12-2014, 12:17 AM | #10 |
Rep 138
My dislike regarding the manual is that the stick travel is too long...does this noticeably reduces that travel!? Doesn't seem much shorter that the stock knob...
05-12-2014, 02:44 AM | #11 | ||
Law Enforcer
25063
Rep 22,282
Drives: '22 Chalk Gray Porsche C2S
05-12-2014, 08:29 AM | #12 |
Rep 42
My experience is that it does seem to noticeably shorten the throw even though it only seems slightly shorter height wise. Think the fact that its also smaller diameter also helps shorten the throw.
05-12-2014, 09:01 AM | #13 |
Rep 199
A shift knob will not shorten the throw unless the stock shift knob is significantly taller than the replacement. The only way to improve shifter precision and shorten throws is by replacing the shifter mechanism with one designed to do just that. You may improve the feel in your hand with a different knob, but that's it.
05-12-2014, 09:46 AM | #14 |
Rep 42
It will shorten it and so will the diameter of the Knob, simple maths/physics, although it wont shorten it as much as short shift mechanism but its certainly noticeable. The precision is something else but also feels slightly better because of the reduced throw and feel the smaller gear knob helps here as well.
06-08-2014, 12:06 PM | #15 |
Rep 2,363
Anyone who has installed themselves, how hard was it to do?
I have the part and want to do it but I want to know what Im getting myself into. Seems like the boot is easy to get off but then I've read mixed on what to do to pull it off? Just pull straight up? Then when reinstalling will it click in or something? I don't want to accidentally pull off the new shifter or anything like that. Thanks in advance.
Follow my builds:
06-09-2014, 02:50 AM | #16 |
Rep 138
there are some how to videos on youtube...it's pretty simple, but not that easy as you have to apply quite some force in pulling it...the gater comes off pretty easy, but the knob need a real pull...putting it back it the easiest part, just smack the knob in and gently click the gater in!
06-09-2014, 05:36 AM | #17 |
Rep 511
I previously put a shorter gear knob on my E46 and it makes a noticeable improvement in shortening the throw. However it also made it physically harder/more demanding to change so this can become tiresome over time. In the end I switched back to the standard gear knob..
06-09-2014, 10:58 AM | #18 |
Rep 10
I have had short shifters installed in both my 2012 GTI & Audi S4 and my 2004 330i ZHP came with BMW installed short shifter as part of the package. They are (arguably) a bit notchier - but are far more direct & precise. The BMW & Audi short shifters (blanking on manufacturer of my Audi SS at the moment) both had lowered shift height and shortened throws front to back. The GTI short shifter (made by Diesel Geeks) is not height shortened at all - but decreases throws both front to back and side to side. It is just fantastic...as are all of them. Not all short shifters are the same - get the best you can get - well worth it. No idea which is best out there for the 235 or if there is any worth getting just yet...but there certainly will be if not already...
06-10-2014, 07:28 AM | #20 |
samuray
Rep 139
does it make "shorter/more precise shifts"? didnt know that but i changed with PF shift knob. I had it on my 128i and i was used to that shape so I changed my 235i anyway.
06-10-2014, 03:59 PM | #21 |
Rep 10
I doubt that the nob will do this for you - though a weighted nob might help with easing into gear. You will need a true short shifter for the greater precision and to shorten throws. Not everyone likes the feel - as it will often be a bit notchier through the gates. I for one would never go back...though I have experienced a short shifter (that was on a used car that I purchased already installed) that I didn't like at all...replaced with the superb Dieselgeeks and I've never looked back - tremendous improvement in all aspects of shift performance 9and no notchiness at all really). I doubt they make one for the BMW 2 series - but you never know...
Current Rides:
2012 VW GTI (APR stage 3+) 2004 BMW 330i ZHP 2001 Audi S4 Avant (AWE Stage 3) 1964 1/2 Mustang Vert (289 V8) |
06-10-2014, 10:14 PM | #22 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Put on the shifter/boot today.. boy was that installation a pain (removal) but otherwise easy.
Definitely changed the driving experience for the better... very happy.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
