07-09-2022, 06:22 PM | #1 |
BimmerPost Supporting Vendor
3757
Rep 2,908
Drives: 2011 E93 M3
VANOS Cover Cups for S65, by Mporium
For several years our shop Mporium BMW Service has offered a permanent solution to the failure prone plastic VANOS spring covers. Until now these components have only been available internally for our own shop's engine work and in-house customer repairs. In light of the increasing interest in vanos repairs we have decided to make our humble product available to the world.
The original adjusters have a plastic cap which serves a simple function- to cover and retain the adjuster’s coil spring. This spring helps returns the cam position to its end point when oil pressure is absent so that it may lock in place for correct startup timing. It also serves to buffer and smooth cam movement when in operation and augment adjustment performance against cam drag in timing advancement. It is important to maintain this spring’s function. As these engines age and the original VANOS adjuster plastic caps become brittle and fall apart, this causes several critical concerns. Most obvious is the debris from the original caps falling into the oil sump and causing blockage of the oil pump pickups. In the worst cases this can cause oil starvation and engine failure. With the cap covers missing from the VANOS adjusters, the springs are no longer retained properly against the adjuster body and risk “walking” forward on their locating pins and eventually coming free. This may not always result in faults or obvious running issues but has been proven to be the cause of broken internal VANOS rotors and spring contact with the engine timing case and valve cover which results in additional metal shavings being introduced into the engine. It is critical to maintain spring retention and unfortunately these plastic caps are not available separately from BMW. Our design is simple but unique when compared to clip-on solutions in that the "cup" is held completely captive under the VANOS’ central bolt. Completely streamlined, it is impossible for it to come loose or break apart. There are no clips to ensure are installed correctly or which might come loose. For this application, a captive design is absolutely preferable for long term reliability as it leaves no chance that the spring cover can come loose, vibrate free, or fatigue and fail as has been observed multiple times with clip-on caps. More refined than oversize washer discs, our "cup" design fully encompasses the VANOS spring in a more OE fashion. We believe our solution is the best option available for this application and is ideally installed during engine assembly or top-end work such as camshaft replacement or valve cover service. *Customized laser engraving is also available. This is often requested if you’re installing custom cams and want the specifications engraved. Details:
NOTE: This permanent fix requires releasing the VANOS central bolts with the cams locked while at #1 TDC. Timing must be checked after installation, and we recommend considering this job during renewal or replacement of the valve covers. Luckily, the S65 is one of the easiest BMW ///M engines in which to set cam timing. The following OEM parts must be replaced during installation: (4) 11367840998 Central Bolt (4) 11367839292 Vanos O-Rings (2) 11317507432 Crush washers (at tensioners) (2) 11127838162 Access cover gaskets We offer this upgrade in two ways: VANOS cups only: Four (4) cups for $379 shipped (standard/ground). Worldwide FedEx express shipping is available. VANOS cups with install kit: Four (4) cups, + required OEM parts (listed above) for $489 USA orders can be made on our site. Worldwide Priority shipping is $50. Please email us or send me a PM and we will forward an invoice. Order on our site: https://mporiumbmw.com/product/vanoscups/ TOOLS: We also offer rental of the S65 timing tools for $99 per week (7 calendar days). We have several tool sets available on a first come first serve basis. $200 tool deposit is refunded with timely return. Tool rental not available for international orders. 7 day rental period starts on day of tool delivery as verified by tracking number. Return shipment of tool must be confirmed as in the possession of shipping service via tracking by end of next business day after day 7 to avoid assessment of additional rental period and/or forfeiture of tool deposit. Tool rental includes printed and laminated instructions for engine timing/checking from BMW’s TIS documents. We do not accept any liability for incorrect use of tooling or improper installation resulting in any property damage. We do not offer technical support for installation by unqualified individuals. Last edited by deansbimmer; 12-03-2022 at 09:05 AM.. |
12-03-2022, 08:55 AM | #2 |
3757
Rep 2,908
Drives: 2011 E93 M3
Our cups are in stock ready to ship!
As a special option you can specify to add custom text to each cover. Great if you're a shop or want custom cams noted on the cover. As we have our laser on-site it doesn't add any lead-time. |
12-04-2022, 07:14 AM | #3 |
Rep 1,036
Drives: BMW M3 e92 08 & 330d e90 10
Fantastic looking product, tempted to buy your cups myself, especially seeing as I'm leaving the Suzuki dealer soon to work at a BMW one! (they should have the special tools! ).
One question, you mention here (and on your eBay advert) - A captive design is preferable for long term reliability as it leaves no chance that it can come loose, vibrate free, or fatigue and fail as has been observed with clip-on caps Are you referring just to the OEM plastic ones or the metal aftermarket ones too? If both, do you have any evidence of the metal ones failing? If so I'd like to see photos of that (as I'm considering the clip on ones to save time). If not, you ought to clarify your advert. If this isn't the place to ask, please direct me to where, or create/ask me to create a new thread. Cheers Mark D. (a previous customer of yours).
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 04-19-2023 at 04:33 PM.. |
04-19-2023, 11:36 AM | #4 |
Rep 615
Drives: E92 M3 6MT Space/Black
Very nice solution ! They look robust, too.
GM |
deansbimmer3756.50 |
04-22-2023, 07:35 AM | #5 | |
3757
Rep 2,908
Drives: 2011 E93 M3
Assimilator1594.00 DrFerry6730.00 |
04-24-2023, 03:33 PM | #6 |
Rep 204
Have had experience with all 3 types. By far, Mporium is the best solution! The best peace of mind for never coming off and not too heavy and thick on the cam adjusters.
08-07-2023, 12:06 PM | #7 |
Rep 255
How much to have you guys install? And approximate turnaround?
E90 ///M3 Silverstone II '11 (current)
E90 ///M3 Silverstone II '08 E46 ///M3 Alpine White III E36 ///M3 Arctic Silver E46 ///M3 Carbon Schwartz |
09-04-2023, 11:01 AM | #9 |
3757
Rep 2,908
Drives: 2011 E93 M3
When we do these in our shop, they're almost always done in conjunction with new valve covers and seals. It takes advantage of the massive labor overlap. We only add 1hr labor to the overall job scope when done that way.
DrFerry6730.00 Fooksdaddy108.50 |
09-05-2023, 03:30 PM | #10 |
Rep 255
Appreciate the response, I literally just did the valve covers and the “other” vanos clip on retainers in the garage.
11-21-2023, 04:31 PM | #12 |
3757
Rep 2,908
Drives: 2011 E93 M3
11-27-2023, 07:18 AM | #13 |
Rep 23
Thank you for providing this option! I want to give this a try because I am going to to the valve stem seal replacement (to fix oil consumption) and the VANOS gears have to be removed anyway. This is a good timing to improve the cover, I believe.
A DIY lover who has done to his 2008 E90 M3:
-Heated steering wheel retrofit -Top HiFi to Individual Audio retrofit -HiFi to Logic 7 (Top HiFi) retrofit -OEM backup camera retrofit -E9x M3 M-Drive retrofit |
DrFerry6730.00 |
