08-06-2017, 09:01 PM | #4 |
Rep 1,930
Dinan is less than h&r.
www.nybmwcca.org
08-07-2017, 03:48 AM | #5 |
Rep 1,091
M-Performance lowering kit: -10mm drop all 4 corners (and BMW warranty intact)....
Piotr
previous: 2003 E46 330i SMG
x233285.50 |
08-19-2017, 12:48 PM | #6 |
Rep 117
Thanks to x233
Eibach is 20 mm front 10 mm rear for RWD, 15 mm front and 10 mm rear for AWD. H&R - there are 2 versions, one that's everyone is talking about which is 25 mm or more front and rear, and there's one with 15 mm all around - these are for RWD. for AWD there is only a -25 mm version. Vogtland - 15 to 19 mm all around Megan Racing - 25 mm all around Last edited by Bombermon3; 11-26-2017 at 08:14 AM.. |
baege1404.00 |
08-19-2017, 12:55 PM | #7 |
Rep 117
https://www.getbmwparts.com/partloca...catalogid=4462
$579 for M-performance springs.. or https://parts.bmwofsouthatlanta.com/...502411196.html Part# 33502411196 Last edited by Bombermon3; 09-09-2017 at 12:21 AM.. |
08-19-2017, 02:33 PM | #8 |
Rep 5,516
Is there anyone running this M Performance spring kit? There's so little information from the forum and vendors about these. I'd love to have a 10mm, more spring rate, and a factory part.
08-20-2017, 09:13 AM | #9 |
Rep 343
For xDrive, ST Suspension, they're 10 mm.
For RWD I'd say OEM M Performance kit |
Theblackginga13.50 |
10-03-2017, 11:29 AM | #11 |
Rep 117
Talked to my Dealer in Orlando.. They say they don't have MP springs for the M235i.
They ones they do have, they think its the same as on the car.. part no. 31336865635 33536865638 |
10-04-2017, 11:13 AM | #12 |
Rep 525
Are there 2 part numbers for the RWD? I called H&R and was told there was only 1 part number (28891-2) not too long ago.
10-05-2017, 02:10 AM | #13 | |
Rep 567
28891-2 this one is 25 mm this can be found here: http://web1.carparts-cat.com/default...7107001&12=130 |
cxp213313.00 |
10-05-2017, 10:58 PM | #14 | |
Rep 525
In my defense, if you search for "28896 H&R" then your results will usually point to x-drive or 228i fitment. I didn't realize springs were interchangeable between all F2X models. Good to know. |
x233285.50 |
10-06-2017, 01:21 AM | #15 |
Rep 1,091
Hmm.... Strange, as at lest the front springs should definitely have different rates between the (heavy) M235/240 and (lighter) 228/230. Within M-Performance springs, the P/Ns are different for the I6 and I4 2-series models.
Piotr
10-06-2017, 08:08 AM | #16 |
Rep 567
You have to go to BMW >> 2 Coupe (F22, F87) >> M 235i >> Sport Performance Springs >> Suspension Kit, coil springs. That way it'll give you 2 options:
(site language can be changed to English in the right upper corner before you select your vehicle make and model) You can open/download the TUV certificate for each part number that'll give you specific details on the springs application/suitability and relevant technical data. |
cxp213313.00 |
10-06-2017, 11:27 AM | #17 |
Rep 525
Thanks! I didn't know you could change the language. I just clicked around, lol.
Too bad H&R doesn't provide their spring rates, like it's some sort of trade secret. I didn't see it listed in the documents and I didn't get an answer when I spoke with the rep last time. These springs sure feel soft, though, considering I can easily compress them with my hands. |
01-08-2019, 02:16 PM | #18 | |
Rep 175
Thanks for the info, if anyone knows! Best, M |
01-10-2019, 12:20 AM | #19 | |
Rep 175
01-12-2019, 06:47 AM | #20 |
Rep 105
I'm in the same boat mate - I'd like to stiffen-up the suspension but really don't want it any lower.
2015 M235i 6MT | Alpine White/Black Dakota | MPerformance Body Kit | 19" M-Sport 359s w/Pilot Sport 4S (r:255/30 f:225/35)
BMS JB4 w/Bluetooth| Wagner Competition IC | Wagner DP | Evolution Raceworks IC Pipes | Dynan CAI | BMS Catch-Can | Active Autowerks Axle-Back | ECS 2-Piece Rotors/Hawk HPS 5.0 Pads | Full MP Carbon/Alcantara Trim | M-Performance Alcantara/LED Steering Wheel |
WolfGTI740.00 |
01-13-2019, 01:09 PM | #21 |
Rep 148
Look at Swift Spec R's for the 2014+ 335i.
They fit and they work. 4.5 k spring rate up front and 11k spring rate in the rear. Ride height will come out to about 22.5" front 23" rear. YOUR GONNA LIKE IT!!!! If your looking for a performance upgrade and not just a beauty spring. |
01-13-2019, 03:07 PM | #22 | |
4210
Rep 3,880
