03-03-2016, 07:00 PM | #23 | |
Rep 557
There is also BMW apps feature, and if your car has that it adds many cool features. It can stream webradio from your phone, pandora, facebook, gopro - all controlled right on the idrive screen. Check these features out, learn how they work, and leave phone holders for peasant's vehicles. |
03-03-2016, 07:35 PM | #24 |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
I use mine for waze only. Everything else is integrated into nav screen.
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
03-03-2016, 08:27 PM | #25 | |
Rep 1,016
03-04-2016, 08:40 AM | #26 |
Rep 1,931
or landscape: I have since put the magnet inside the battery case and it seems to be holding...
www.nybmwcca.org
03-04-2016, 10:49 AM | #27 |
Rep 1,753
Is there a thread showing how to run a wire up through the vent to charge a permanently mounted phone? I can't find a thread.
03-04-2016, 11:47 AM | #28 | |
Rep 103
03-04-2016, 09:35 PM | #29 |
Rep 14
03-04-2016, 09:45 PM | #30 |
Rep 1,931
The vent still works.
Here is my new vent mount
www.nybmwcca.org
03-04-2016, 09:49 PM | #31 |
Rep 14
What about when they ask why you don't use the giant screen on the dashboard and the aesthetic oddity of placing your cell phone on a mount atop the vent?
Also, obstructions are known to interfere with airflow. |
03-04-2016, 09:52 PM | #32 | |
Rep 1,753
03-04-2016, 10:05 PM | #33 |
Rep 1,931
Millennial666: are you serious? Air flow?
No one has ever asked me about why its there, if they did thats when i pull over and say get the f' out. It's a cell phone dedicated for monitoring, it doesn't leave the car. If you want to replace the vent with a monitoring system be prepared to pay $300 - $1200.00. Or go with the Cell Phone and Saddle 2 with Torque for $12.00. Or don't monitor at all and guess at all your values.
www.nybmwcca.org
03-04-2016, 10:38 PM | #34 | |
Rep 14
Removing the vent and replacing it with a cell phone is an even worse solution. I have no idea what you're obsessively monitoring, but your values have been poorly monitored if you think kicking passengers out of your car for simply asking about your bizarre decisions is not acceptable behavior. |
03-04-2016, 10:40 PM | #35 | |
Rep 14
03-05-2016, 07:39 AM | #36 |
Rep 1,931
you have no idea what we are talking about.
On a cold day monitor oil and coolant temp, regular driving battery, boost/vacuum, AFR, etc... Who cares if your passenger is hot or cold. You dont replace an air vent with a cell phone:
www.nybmwcca.org
03-05-2016, 10:17 AM | #38 |
Rep 1,931
Mostly Coolant since its been cold- I cant seem to get a dial for OIL Temp, but i've found coolant over 160f means the car is warmed up. The oil temp does show up in the first screen that shows all the cars data. So it is available, I just cant seem to make it its own gauge. Plus i like the audio voice that tells me "operating temperature has been reached" or "icy conditions"
I also monitor boost/vacuum, batt, AFR, gas milage, rpm, hp, I use track reccorder for hpde's... I have played with the gforce meter but don't think its super accurate, some of the other apps available track that much better. It also clears codes, but I haven't had to try that out yet. Its a great tool since our cars lack the gauges by default. Well priced for what it provides. It does take a little time to get everything setup correctly, but once its dialed in, it works great.
www.nybmwcca.org
03-05-2016, 02:08 PM | #39 | |
Rep 886
I'll have coolant up over 200 within 5 miles of leaving my house. At that point, the oil isn't even past 160. You need a minimum of 10, more likely 15, miles of driving at highway speed before your engine is warmed up (oil >200F) on a below freezing day.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 03-05-2016 at 02:30 PM.. |
03-05-2016, 02:30 PM | #40 | |
Rep 1,753
03-05-2016, 02:33 PM | #41 | |
Rep 886
There's a reason beyond "because it's a fun thing to do" that people recommend you take your car on a 30 minute or more drive every week or so. 15 minute commutes are brutal on your oil. You need to get it fully hot to boil off all the things that accumulate in it on short hop drives.
03-05-2016, 02:42 PM | #42 | ||
Rep 1,753
03-05-2016, 06:02 PM | #43 | |
Rep 886
Also depends how long you plan to keep your car. I tend to keep them a long time (131,000 miles on my 335 / 190,000 on my Passat) and if you plan on long term, the turbos and other bearing surfaces will thank you.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 03-05-2016 at 07:44 PM.. |
03-05-2016, 06:16 PM | #44 | ||
Rep 1,753
