02-04-2016, 07:09 AM | #1 |
Rep 7
Locking the car without the key
I do not have comfort access. I live in the US.
Is there a way to lock the car without the key? I'd like to be able to exit and lock the car without the key but the button on the dash won't lock the doors if they're open. If I leave someone in the car for a minute while I run into a store and they decide to come in later it's impossible for them to lock the car without a key. This is a problem even if you have comfort access. <edit - Passenger door can be locked.> From what I can tell I have to press the button on the remote or stick the key in the door once I've exited the car. I must be missing something. Please help. Last edited by BMW228i; 02-05-2016 at 09:22 AM.. |
02-04-2016, 09:13 AM | #2 | |
Rep 134
02-04-2016, 09:26 AM | #3 |
Rep 1,209
You need the key to lock the car from outside. It prevents you from locking the key in the car. Even with comfort access, the key has to be near the car to lock the doors from outside.
2017 X5 35d (Performance Center delivery March 2017)
2019 230i X-drive 2022 M3 base 2000 328i sedan (UUC suspension - still the favorite), 2006 M3 slick top - Alpine White/Cinnamon SOLD! 2008 E90 M3 SOLD! 1991 325iX (both great), 2019 Miata RF - various others not as memorable but gone. |
02-04-2016, 09:41 AM | #4 |
Rep 7
Pushing on the actuator doesn't work. Even if you pull on the handle at the same time.
With keyless ignition it's odd to need the key to lock the car. Reading some other forums it seems this is by design to prevent lockouts. The passenger door, at least on older BMWs, will lock with the dash button when it's open. It's probably the same with this car. If someone has a work around that'd be neat but I'll be fine. |
02-04-2016, 10:47 PM | #5 |
Rep 79
Drives: 2016 228i Coupe, M Sport, 6MT
Garage List 1980 Mercedes 240D ... [0.00]
2004 BMW 325Ci Coup ... [0.00] 1997 Jaguar XJR (gone) [0.00] 1985 Jaguar XJ6 (gone) [0.00] 2016 BMW 228i Coupe [0.00] 1995 Mercedes E320 ... [0.00] |
Get in passenger seat, shut door.
Press central locking button to lock yourself in car. Double pull passenger door handle to open door so you can let yourself out. With the door open, manually press the little lock down on the door. Shut door. You have just locked car without key. NOTE. This does not arm alarm and this will not work on drivers door.
-Christopher
