06-21-2022, 12:11 AM | #1 |
Rep 232
Need Alignment Help
Hi,
I just got my car back from an alignment and I noticed that the front left caster is a bit more positive than the front right. I did some spirited driving yesterday and kept rubbing on the driver side. I've attached the alignment sheet to the post. My mods are: Millway Street Camber Plates Dinan Lowering Springs + Bumps Stops Koni Sport Front + Rear Shocks Does anyone know why the caster could be different? |
06-21-2022, 07:01 PM | #3 |
Rep 232
06-21-2022, 10:51 PM | #4 |
Rep 5,262
Not sure.... but I doubt the alignment did anything to cause the rubbing.... probably it was always there.....
are the tires new?.... when I put 245-40-17 RE-71Rs they would rub a bit under load but those are wider than stock... |
06-21-2022, 10:58 PM | #5 |
Rep 232
No, tires aren't new. Indy 500 245/40/18. They have about 10k kms used
06-21-2022, 11:12 PM | #6 |
3708
Rep 3,621
Although BMW doesn’t specify a specific castor angle for the F2x, they do specify a maximum difference from left to right of 0.5 degrees (30’).
