09-29-2015, 11:13 AM | #23 |
Rep 3,834
The M2 is technically a modern day E46 M3 equivalent. Similar wheel base, weight, but more power. I thought that was the goal of the M engineers.
Daily: G12 750 MSPORT Weekend Car: E90 M3
09-29-2015, 11:53 PM | #24 |
Rep 11,785
that would be 100 lbs more than the 1M.... I just can't believe it will be that heavy.. also can't really see it being that close to the M4...
09-30-2015, 04:35 AM | #25 |
Rep 11
I expect the weight of the M2 to be the same as the M235i.
Some parts of the M2 a lighter, some parts are heavier. I dont see any chance für 100lbs less. Maybe 20. The M2 is the entry level M with the lowest price. It does not make sence to make it too good! There is also the profit margin in the background. No space in budget for CF and so on. The M2 is a M235i with more power and improved brakes and chassis and a more sporty transmission, not more. Lower your hopes..... I think more and more about a second hand Cayman GTS (about 1 year old). One think more. In Germany the first B58 340i are on the road. Owners report it's a much improved engine compared to the N55. Revs more freely, more direkt throttle response, less fuel consumption. So it's a little bit disapointing that the M2 does not get a tuned B58.
2015 F32 430d M-Sport PPK
2014 Porsche Boxster GTS (2014 E89 sDrive35is had to go) Last edited by Acky; 09-30-2015 at 05:11 AM.. |
09-30-2015, 07:25 AM | #26 | |
7485
Rep 12,307
When I drove the M235i, it didn't feel THAT heavy to me and those cars at the Performance Center were more or less fully loaded. Definitely heavier than my E36, but also much lighter than my E92. Which is OK by me
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
10-01-2015, 10:54 PM | #29 |
Rep 2,601
10-04-2015, 01:17 AM | #30 |
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
3450 lbs
10-04-2015, 05:44 AM | #31 | |
Rep 5,560
Maybe with a power upgrade too |
10-13-2015, 01:22 PM | #32 | |
Rep 11,785
ok gang.. I am trying to find some consistent figures... I show that the 1M curb weight is 3296 lbs.... 77 less than the 135 135 curb weight is 3373 lbs I also see figures that the M235 curb weight is 3535 lbs.... The article released today seems to have confused some specs... it mentions a weight loss off 77 lbs from M235 to M2.. oddly the 77 lbs figure is the same for the 1M to 135... but that does not make for a curb weight around the reported 1495 kg.... ? |
10-13-2015, 01:38 PM | #33 | |
Rep 2,234
It appears Auto Express are quoting the DIN weight and then comparing it with the M235i EU1 weight by mistake and thinking it has a 35kg weight loss. I expect when the official press release is out, the M2 will have a DIN weight of 1,495kg, which is 1,570kg EU1 (DIN +75kg for the driver). The M235i EU1 weight is 1,530kg. So the M2 appears to be 40kg HEAVIER than the M235i. The M2 in Euro spec will be 3,461lbs. |
10-13-2015, 01:40 PM | #34 | |
Rep 11,785
10-13-2015, 01:40 PM | #35 | ||
Rep 36
This means that, if you compare the correct weight figures, the M2 is actually 40 kg, or ~88 lb, heavier than the M235i.
-Ken
M2 or GT350? Hmmm... |
10-13-2015, 01:44 PM | #36 | |
Rep 11,785
I fell like I am still seeing 1495 for the 1M ? |
10-13-2015, 01:54 PM | #37 | |
Rep 36
DIN: 1495 kg EU1: 1570 kg So if these numbers are correct, the standard EU-model M2 will weigh the same as an EU-model 1M. This would mean that the M235i is actually lighter than the the old 135i Coupe, then? It will definitely be interesting to see the US curb weight numbers.
-Ken
10-13-2015, 03:48 PM | #38 |
Rep 1,963
Why do they have to make it so hard? Politicians have to mess everything up don't they...just weigh the car with all fluids and full tank of gas. There done...see how easy that was?
