03-27-2017, 09:48 AM | #1 |
Rep 671
230i/228i Brakes any good?
My build still hasn't been officially scheduled and I'm wondering if I should add the Track package for the better brakes or if the standard brakes will be sufficient.
I don't plan on running my car at any track, but I do enjoy some spirited driving now and then... BTW, in the past, I've been pretty hard on my brakes on all prior vehicles... As in I've warped plenty of rotors on cars.. I've never warped a rotor on a truck, but every car I've had, I've warped rotors... except on a '93 Nissan Sentra... which cracks me up.
'20 240ix convertible
03-27-2017, 09:59 AM | #2 | |
Rep 2,010
03-27-2017, 10:14 AM | #3 | |
Rep 671
Now it's not like this everyday, but it only seems like it takes one time to warp a rotor... I can go 30K miles without an issue than next thing I know, my rotors are warped.
03-27-2017, 10:31 AM | #4 |
Rep 2,873
I've never felt like I was close to brake fade or failure, with some hard driving and a lot of commuting (rare to even invoke ABS, except in the snow) - I have the 228 with stock brakes and suspension, performance summer tires. I think that, at most, a step up to more aggressive pads would be more than adequate for anything other than dedicated track duty. Msports are probably better (if only better looking), but stockers aren't deficient. IIRC, the brakes alone are a pretty simple replacement, so you can add them later if you want - I think the rest of the Track package is the stuff that may be cheaper to get up front as a package (and ironically, I've seen more questions about that other stuff being worse for track use - like the adaptive shocks and steering).
Brake shops will often use the term 'warped rotor' to describe anything objectionable in terms of pulsing or uneven stopping - I'm told it is most often some kind of issue with heat glazing, or failure to do the initial bedding in properly (I've never had a brake place or dealership even suggest bedding-in procedures). |
03-27-2017, 10:35 AM | #5 |
Rep 269
I will withhold comment on your driving habits and life outlook and say only that modern rotors really don't "warp". It's much more likely that you are braking hard/frequently, getting your rotors super hot and then stopping without time for your brakes to cool. This causes transfer of pad material onto the rotor surface which would then cause the pulsation often attributed to warped rotors.
03-27-2017, 10:50 AM | #6 |
Rep 671
Thanks guys... I guess the base brakes will be fine.
I did do a search on the forums for "warped" and I didn't come across any posts for warped rotors... That's a really good sign, for me, that the base brakes are probably fine...
03-27-2017, 11:53 AM | #7 |
Rep 6,028
Now that you're feeling all settled, the Track Package combination from brakes to steering to suspension is a great value and does transform the feeling of the car. Strongly suggest you reconsider if you enjoy "enthusiastic" driving.
03-27-2017, 02:25 PM | #8 | |
Rep 671
What kind of difference will I feel? Does it handle that much better when trying to run from the po po to avoid a ticket? These days the po po cars are FAST, but I don't think they handle well.
03-27-2017, 04:17 PM | #9 | |
Rep 6,028
BTW, keep in mind this comes from someone who swapped out the M4 lower control arms for even more steering responsiveness and handling, so this is the aspect of the cars I appreciate the most! What about you??? Also, not sure if it matters to you , but I find the Comfort setting helps alot when my significant other is aboard. She doesn't prefer the Sport experience. Two cars in one!
03-27-2017, 04:24 PM | #10 | |
Rep 671
I'm thinking this little 230xi Vert is going to be heads and tails above what I've become accustomed .... Still better is better... so I need to see if I can really feel a difference. I may be totally numb because of these past vehicles.
03-27-2017, 04:34 PM | #11 | |
Rep 6,028
03-27-2017, 05:57 PM | #12 |
Rep 138
I think the brakes should be just fine. Only time I had some issue with my brakes was right when was when the car was new and it was still breaking in/I was getting used to it. Otherwise I've actually found them quite responsive yet not harsh.
03-27-2017, 07:01 PM | #13 |
Rep 6,028
You are absolutely correct. But, for me, if the standard was "just fine" for something related to the chassis, I'd probably be in my Subaru or a Honda full time. For what goes into buying and owning a BMW, and my expectations from the brand, I'm looking for a smile plastered on my face for each drive. The THP delivers that for me.
03-27-2017, 07:14 PM | #14 |
Rep 671
Just left the dealership.. Test drove a M235 and 230i back to back... Knowing I didn't need THP, I still ordered it.
Guys, do not let me go back to the dealership till my order is here...
03-27-2017, 07:25 PM | #15 |
Rep 6,028
LOL...the deed is done. You'll long forget the price when you're still smiling during the drives. Congrats!
crabu2141.50 |
03-27-2017, 09:07 PM | #16 |
Rep 671
I post this because I'm worried about the base brakes... I end up ordering the THP, not because of M brakes, but because I just had to test drive a car with it...
I did notice something that was odd.. When you go into the sport setting on the 230, there's an option to set the Chassis, Drivetrain, or both. If the chassis setting doesn't do anything ... at least I didn't feel any change ... why is there a chassis setting? On the M235, there was a clear difference when I played with the setting.. but not on the 230. BTW, I ordered the THP not just because I enjoyed the tighter suspension, but because I noticed without it, when I goosed the go peddle, the car would nose up like I was in a boat. Oh the other reason was that the tighter suspension really makes the car feel like a roadster. Now I need to find me some stock 17 inch wheels for the winter...
03-27-2017, 09:13 PM | #17 | |
Rep 5,262
03-27-2017, 10:06 PM | #18 |
Rep 671
Thanks for the info.. When I switched the mode on the 230, it did feel like something was different, but it didn't feel like it was in the suspension. I thought it was just in my head, but now it makes sense why I felt something was different.
03-28-2017, 12:21 AM | #19 |
Rep 260
03-28-2017, 09:01 AM | #20 | |
Rep 671
Order status 112 is the magic status you have to be at or below. Based on my current experience, at the very end of status 112 is when the build date is set. So you can be in status 112 and not be able to modify it. Yesterday when I was at my dealer, I could see on his screen, my order was in status 112 and it was highlighted in yellow, meaning it could be modified. I saw a couple in status 112 that was red, that meant no modifications would be allowed. I still don't have an actual build date schedule, just a build week of 16. BTW, if you dealer modifies an existing order, by the next day you might not be able to modify it..
03-28-2017, 09:19 AM | #21 | |
Rep 2,873
And FWIW, make sure you have the summer performance tire option (might be part of THP?) - that way you get staggered width, and they raise the HP limiter to 155 or 160 - but remember that you can't outrun a Motorola |
03-28-2017, 09:48 AM | #22 | |
Rep 6,028
