05-06-2024, 07:35 AM | #1 |
Rep 7
Advice needed
Dear all,
I recently purchased the AA resonated single mid-pipe for my 2019 BMW F87 M2 Competition. I’m now thinking of adding the M Performance exhaust and was wondering if I can do this without having to cut the MPE to cater for the set-up as I had to cut 1” and 6.25” from the original back box to fit the AA mid-pipe. I’m reaching out in the hope that someone can let me know if this is possible and also your advice on the set-up that I’m planning which consists of OEM down pipes, AA resonated single mid-pipe and MPE back box. Thank you. |
05-06-2024, 07:17 PM | #3 |
Rep 34
My setup was OEM downpipe with MPE then added the AA single resonated midpipe later on. My OEM midpipe was cut to accommodate the MPE but the MPE does not get cut ever.
05-06-2024, 07:38 PM | #4 |
Rep 3,827
The MPE connection points actually won’t reach the connecting pipes. The previous owner of my car tried to scab in a short length of pipe to make up the difference but it was a leaky mess. I chose to extend the connecting pipes via welding an extension.
RS2OOO9.00 |
05-07-2024, 12:53 PM | #5 |
Rep 34
I did exactly what allinon72 did as well. Weld extension piping to the AA link pipes to utilize the MPE clamps. My pipes were able to connect, just barely, using the AA provide clamps but wanted a more secure connection.
05-07-2024, 02:54 PM | #6 |
~Spyder
645
Rep 879
Drives: '19 M2C Hockenheim 6sp
Mirroring what others have already stated: you need connecting pipes to mate AA EL to any back box. They normally come with your AA mid pipe purchase
Here is my AA EL (non resonated) connecting to Dinan axle back. I highly recommend paying a small fee to have a shop tig-weld all connections. The brackets are at best a temporary solution and you will have exhaust leak.
Skål från Sverige...via Texas y-all
05-15-2024, 07:50 PM | #8 |
~Spyder
645
Rep 879
@SirPsychoMD
That is not a full length exhaust straight from AA is it? Cause, hot dayum...that's is some PRECISION WELDING there sir. Mega clean
05-16-2024, 04:42 PM | #11 |
Rep 11
No_curebimmer645.00 nismosao211.50 |
05-17-2024, 12:25 PM | #12 | |
~Spyder
645
Rep 879
The shop is top notch - master welders! P.S. can you post other shots showing different angles for the AA - Dinan mating portion?
nismosao211.50 |
