07-09-2016, 01:02 PM | #23 | |
Rep 199
Drives: M235i xdrive
Here is the link http://jrc-designs.com/products/
SOLD: 2015 BMW M235i Glacier Silver on Coral Red
35% tints, Gloss Black Roof, AFE Magnum Force Stage 2 Intake, AFE Power Scorcher, P3 Vent Gauge and Fabspeed muffler delete. |
07-09-2016, 01:18 PM | #24 |
Rep 227
For those that keep asking where this is, it is on the left side of the muffler under the car if you are looking at it from the rear. Very obvious to see if you look under the car.
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
07-09-2016, 02:10 PM | #25 | |
Rep 1,753
07-09-2016, 04:45 PM | #26 |
Rep 610
If you're interested, here's an option for folks who don't want to spend any money to disable the valve, and keep the electrical connection intact/safe from debris, weather, etc...
Yep, you can unplug it, wrap the plug to weather-proof it & tie it off to secure it. Here's another option. There is a C-shaped clip that connects the motor that turns the valve to a stem at the top of the valve. It's like a spring that sits in slots at the bottom of the motor's stem & the top of the valve's stem. Remove that clip & the valve opens/closes freely. Hold it in the open position & tie it in place with a bit of bare wire. You wrap the wire around the exhaust pipe, place it in the slot while the valve is in the open position, twist the 2 ends together to secure it. Hopefully, the pics I attached help show what I am talking about. This is the stock exhaust I removed when I installed the M Performance exhaust. I did this mod on the M Perf exhaust after installation once I saw how this worked. I was going to do the unplug/weatherproof/tie-off option, but I liked leaving it plugged in. You only need to jack up the driver's side rear. Secure your front wheels & use a jack stand if you have one. Pic #1 shows the valve assembly & the screwdriver is pointing to the clip. Pic #2, use needle-nose pliers to squeeze clip & remove. Pic #3 shows what the clip looks like. Pic #4 shows valve stem turned to the open position. Pic #5 shows wire wrapping around pipe & in the valve stem slot, securing it in open position.
2017 M2 | MGM | 6SPD Std | RWD | MP Exhaust | CSF FMIC | Active Autowerke DP w/ HF CAT | FTP Charge & Boost Pipes | Fortune Auto series 500 7k/14k coilovers | CDT Audio ES Gold Fronts & HD series Rear | Richland Forged Project Nurburg RF-GT4 Wheels | AudioControl LC-6.1200 | JL Audio TWK 88 | CF Goodies
Climate Changer110.00 |
08-18-2017, 11:40 PM | #27 |
Rep 27
Drives: Alpine White M235i xDrive
Sorry to revive a dead thread but after lurking around the F80 forum when stumbling on ways to disable the exhaust flap I figured I'd test the method they had with pulling the fuse for the valve and it works. Removing fuse 146 from the rear fuse box will disable the valve so as long as you make sure its open, which I did by starting the ignition but not the engine, placing the car in Sport+ mode and holding the gas down then turning the car back off you can remove the fuse and the exhaust valve will remain open.
03-27-2019, 12:59 PM | #29 | |
Rep 278
My issue is the the clip itself it makes the exhaust flap rattle issue. Is there no harm in removing it? Great added bonus as well |
01-25-2020, 12:48 PM | #30 |
Rep 1
My "C" clip broke and i had that rattle issue so i bring it to my shop and asked him to let the valve open. He did use bare wire but now i have an annoying sound when the car tell the valve to open or close. It's like a pulse sound.
07-17-2020, 02:23 PM | #31 |
Rep 776
I know this is a 4 year old thread, but there's some good info in here.
I put my 2017 M240i in accessory mode (engine off), pressed gas pedal to the floor, heard the valve open, shined a light inside to confirm, unplugged the valve, then took the car for a drive. I noticed absolutely zero difference in acceleration or deceleration sound in Comfort or Sport mode... is it just me? I was under the incorrect impression Comfort mode would get burbles, which it does not, but even ignoring that the exhaust sounded the exact same so I just plugged the flap back in. Anyone else experience this?
M240i | Mineral White | Coral Red
07-17-2020, 03:25 PM | #32 | |
Rep 513
E46 -> E90 -> F30 -> F23
07-17-2020, 03:47 PM | #33 | ||
Rep 776
I don't want that to happen again
07-17-2020, 04:47 PM | #34 | |||
Rep 513
