Vorshlag's prototype F22 camber plate - ready for testing |
04-20-2016, 02:09 PM | #45 | |
Rep 957
I run 50 adder, 60 scaling, 6 psi. 20 psi fail. But I only use on track (lots of WOT) , so stop and go may cause the bogging. I use boost juice. You can try messing around with the adder, raising may help if the meth is running too rich. Best bet is to post the logs on n54tech. You could always drop down a nozzel (cm3) for one if needed. Also the system has to learn, it is very hard to get the 4th gear pulls on public roads, I would be doing in excess of 130-140. So track has worked out for that, or you could tune on a dyno. |
04-20-2016, 02:30 PM | #46 |
Rep 18
04-20-2016, 03:37 PM | #47 |
Rep 1,184
04-20-2016, 03:41 PM | #48 |
Rep 845
rwalker had issues with the set of Dinan plates he was testing -- the spherical bearings were shot after 1,500 miles of mixed use (street/autox/track). Dinan is supplying him with new bearings, but it remains to be seen whether this was just a one-time defect or a design flaw.
http://f30.bimmerpost.com/forums/sho...0&postcount=10
04-20-2016, 03:45 PM | #49 | |
Supreme Allied Commander
3847
Rep 54,378
Drives: F80 M3
04-20-2016, 03:47 PM | #50 |
Rep 1,084
I'll comment in the F30 Dinan thread...
05-02-2016, 12:10 PM | #51 |
Rep 845
Can we get an update on the Vorshlag plates? It's been quite a while . . .
05-02-2016, 01:13 PM | #52 |
3847
Rep 54,378
Drives: F80 M3
05-05-2016, 10:04 AM | #53 | |
Motorsports Engineer
46
Rep 95
Also, we should know better than try to introduce new parts during the beginning of race season. #pullingmyhairout
Jason McDaniel at Vorshlag
05-15-2016, 08:18 PM | #55 |
Rep 18
OK, I'll be the guy everyone hates. Either way, I will be buying a camber plate of some manufacture this week. There is this matter of a Pro Solo coming up, you see...
So I'd like to buy Vorshlag, but may have to do something else. This is not meant to be a threat, but rather an inquiry as to the status of camber plate manufacture... At this point, please let us know an ETA, so we can make a decision for this season. |
05-15-2016, 08:34 PM | #56 | |
Rep 1,422
05-15-2016, 09:21 PM | #57 |
Rep 1,084
I'm still alive... but I'm very badly burned
srsly, Dinan plates are working for me, find posts in other threads: this one's for Vorshlag
05-15-2016, 10:28 PM | #58 | |
3847
Rep 54,378
Drives: F80 M3
05-15-2016, 10:45 PM | #59 |
Rep 1,084
given product development and production cycles in this industry, I'd guess July earliest
I'm hoping they're worth the wait 18 months ago, my shop said Vorshlag plates would be available in 6 months, TOPS GC plates took 12 months to sort out to something workable (from initial shipments to what they have now)
05-15-2016, 10:48 PM | #60 | |
Rep 1,422
05-16-2016, 05:08 PM | #61 |
46
Rep 95
We are finishing a run of three other parts on the mill which should end late next week, then F22 parts go into production. After we start I'd say it will be about two weeks of machining and one week of plating (nickle and anodizing) and there is a laser cut part that will require welding and plating and then they should be available.
05-16-2016, 05:43 PM | #62 | |
3847
Rep 54,378
Drives: F80 M3
06-07-2016, 03:24 PM | #65 |
Rep 1,084
w00t!
06-07-2016, 04:42 PM | #66 | |
Rep 129
Drives: 2016 MW M235xi
