06-13-2015, 11:01 AM | #1 |
Rep 986
Best exhaust mods for gains
I've been researching downpipes and full exhausts for the best hp/$ gain. I noticed that most cat-back/axle-back exhausts out there provide relatively small gains < 8 HP, < 10 Ft lb torque for equivalent dollar value $1000-$2500. That the single most gainful mod is tune piggyback or flash, and then catless or race cat version of downpipe, $400-$1200. Intake mods are claiming 10-15 Hp, 10-20 ft lb torque, for anywhere $200-600. There are no dyno graphs I could find with a stock car just showing intake swaps.
Sorted from lowest to highest: N55 JB4 Piggyback ($530) 60 HP / 100 Torque = $8.83/HP, $5.30/FtLbTq ($11.48) Race Catless 4" Downpipe ($500) 21 HP / 36 Torque = $23.81/HP / $13.89 FtLbTq ($18.85) N55 F-series ECU Flash ($1500) 60 HP / 100 Torque = $25/HP, $15/FtLbTq ($20) Burger Tuning N55 Intake ($230) 10 HP / 8 Torque = $23/HP / $28.75/FtLbTq ($25.88) Magnum Force Stage 2 Intake ($450) 14 HP / 18 Torque = $32.14/HP / $25/FtLbTq ($28.57) Race High-flow Downpipe 200cpi ($1200) 21 HP / 36 Torque = $57.14/HP / $33.34/FtLbTq ($73.81) The combination of a piggyback and catless downpipe seem to be the best bang for Hp/Tq/$$$. |
06-13-2015, 11:17 AM | #2 |
Rep 165
catless downpipe and jb4 are your best bang for buck. A full exhaust is useless except for noise. That was my last mod since it costs 2k. Don't cheat yourself the extra 10 hp and $400 going catted. Catless DP with a stock exhaust sounds great.
06-13-2015, 12:54 PM | #4 |
Rep 191,342
Best gains JB4 + Catless downpipes .
Exhaust will not give you any gains, but if you do a full exhausts you will be saving weight which will make your car go faster.
06-13-2015, 01:33 PM | #5 | |
Rep 2,710
Drives: MB E350 4MATIC Estate
I did not want to go catless because I don't want to hassle with California emissions testing and I don't want the potential bad smell you get by not running a cat. |
06-13-2015, 01:36 PM | #6 |
Rep 165
california emissions, I totally get running catted. We don't even do federal emissions test where I'm located. The BMW exhaust is not restrictive. There isn't a single cat or anything after the downpipe (which surprised me under the car). The power gain any of these overpriced shops (Which honestly they are all overpriced because of the car they are going on) are making is due to ECU remapping or Downpipe replacement.
06-13-2015, 01:39 PM | #7 |
Rep 986
The emissions thing is what i've been thinking about. In Mass we have similar requirements and they test yearly to get an inspection sticker. Although the test is all electronic via ODB2, if they noticed the smell they could put the old school test on the exhaust pipe and figure it out
06-13-2015, 02:35 PM | #8 | ||
Rep 678
With the above said the JB4 and catless DP are the best bang for you buck period. Quote:
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
06-13-2015, 03:19 PM | #9 | |
Rep 72
You can go with a Catted downpipe, but that won't even guaranty you won't get a CEL as over time, I have read that aftermarket cats aren't that reliable with the BMW sensors. So from my research conclusions, I believe the best route is just get the catless downpipe with the JB4, and swap it out after 7 years (atleast here in CA) when the first smog check is required. Every other option either will be left to chance that the cat still works well with the sensors or the smog shop guy is lax or incompetent at his job that day. That goes along with hopes that nothing else in the vehicle doesn't start to deteriorate before that time which may require additional maintenance. From my experience, about that time would be when the EVAP sensors and lines start to go as well as the oil pressure sensor or pump. Then again, I drive probably a bit more than your average person, putting easily 20k miles on any given car every year. YMMV. |
06-13-2015, 04:19 PM | #10 | |
Rep 678
06-14-2015, 01:36 AM | #12 | |
Rep 72
This is also the same reason why you cannot reset your CEL using a OBDII reader and go in for a smog. It will give the same outcome as the JB4. The smog shop will either let the engine run idle for a while, or tell you to pick up the car and come back tomorrow or later in the day with it. This is also why JB4 doesn't work well with P3 gauge. Due to the fact P3 takes their data out of the OBDII socket, it won't be able to get a read if JB4 is constantly resetting the computer, causing it to kick out the computer is not ready, which gives the P3 no information to display on the gauge. Last edited by Dattebayo; 06-14-2015 at 01:42 AM.. |
06-14-2015, 08:20 AM | #13 |
Rep 986
It's too bad the P3cars gauge becomes useless with the JB4, but i did read i can run a wire to the MAP and then i can atleast have it as a boost gauge which is fine with me. But i lose my precious oil temp and coolant gauge
