08-24-2021, 12:00 AM | #1 |
Rep 26
High pitched noise after BM3 stage 2
Hi guys, need some input. I just flashed the bootmod3 stage 2 OTS 91 octane map, took it on a test drive and in 2nd and 3rd gear at wide open throttle I hear a loud shriek/whistle noise, it stops as soon as I let off the throttle. Sounds like it’s coming from the left side of the car. The car didnt make that noise with the stage 1 map. It only makes the noise at wide open throttle.
2014 m235i 6mt, 40,xxx miles. Stock intake, MAD charge pipe, MAD intercooler, MAD cat less down pipe, FTP boost pipe. I’d appreciate any input as to what it is, could be, what to look for, any similar experiences. Thanks guys. |
08-24-2021, 09:18 PM | #2 |
Rep 31
If you're on the stock intake, might be a small leak at the charge pipe coupler or IC gasket. Check your clamps and vacuum lines as well just in case
illmatic379.50 |
08-26-2021, 06:12 PM | #3 |
Rep 196
Sounds like a boost leak
Lot more boost to bring out the problems. Smoke test it
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
illmatic379.50 |
08-26-2021, 10:47 PM | #4 |
Rep 5,372
Boost leak. Likely at the IC and CP connection or the CP silicone connections.
illmatic379.50 |
08-27-2021, 08:30 AM | #6 |
Rep 190,807
let us know how it goes
