2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Took my car to BMW service and now my OBD won't connect to my tuning software?
      07-15-2021, 11:52 PM   #1
g80_nick
g80_nick's Avatar
Drives: BMW M3 Competition
hi so i ended up going to BMW to get my spark plugs changed cause my car was idling weird (my car isn't under any warranty or anything i'm just out of town and wanted to get them fixed before the long drive home) and now my car won't connect at all to the tuning software. I've tried 3 different tuning softwares and all of them won't connect. They mentioned my tune and said i should put it back to stock cause that might help it but i said i'm not going too and to just do the spark plugs. It connected perfectly fine before taking it there that same day 5 min before i got there but now all of a sudden it doesn't connect at all and i've tried for 30 min and it doesn't connect. It shows the ethernet in the settings of my phone and my phone even charges through the adapter so it's obviously working but it won't connect. Do you think they did something so i can't connect to my car anymore?
      07-16-2021, 09:36 AM   #2
XutvJet
It may be that BMW has developed a DME lock for the N55s now like has been done for newer B58s and S55s.
spidy512494.50
      07-16-2021, 01:08 PM   #3
g80_nick
g80_nick's Avatar
can they do that even if i'm just getting my spark plugs replaced? I have no warranty or anything i just had to go and get them replaced before driving back. I don't understand why they would lock my DME
      07-16-2021, 01:26 PM   #4
Estoril235
They don't do it just to lock it, it's just built into the latest software update and sometimes dealers update the software as a courtesy even if the service your car is in for isn't computer related. A lot of people here ask dealers not to update software, even if they're just getting an oil change, specifically for this reason.
      07-16-2021, 02:48 PM   #5
g80_nick
g80_nick's Avatar
oh okay i called the dealer do you think they can like re unlock it or something for me? How would i fix this? I emailed PTF so hopefully they can help me fix it.
      07-16-2021, 03:06 PM   #6
Estoril235
I haven't had this problem so I don't know the details, but PTF is your best bet. The dealer likely isn't going to be able to do anything. The only thing they might be able to do is give you an older version of the software, but that's unlikely.
      07-16-2021, 08:18 PM   #7
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
can you connect with a regular OBDII code reader ?
It could be that they might have bent some of the pins in the connector and then it won't make contact.... I remember once I was coding a car and the OBDII connector wouldn't even go in all the way because of this
      07-18-2021, 01:43 PM   #8
g80_nick
g80_nick's Avatar
it seems to go all the way in like it did before and i don't have a regular one :/
714BMW38.00
      07-18-2021, 07:49 PM   #9
pikcachu
pikcachu's Avatar
1403
Maybe stop by any Napa or autozone and see if they can check to connect with an OBDII reader... usually they do it for free...
      08-02-2021, 09:00 AM   #10
DBinOH
Drives: 2020 X5; 2016 M235i Conv. 6MT
Disconnect the battery in the trunk for 3-5 minutes. Then reconnect. Should fix it.
      08-12-2021, 07:16 PM   #11
mcompact
mcompact's Avatar
Drives: 2014 M235i
That's what SHE said...
2014 M235i
2015 X1 xDrive28i M Sport
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
      08-12-2021, 07:27 PM   #12
pikcachu
pikcachu's Avatar
1403
      08-20-2021, 08:44 PM   #13
sard_f30
Drives: 2017 BMW 330i
Did you ever get this problem fixed?
      09-01-2021, 02:20 PM   #14
NateDog07V
Drives: 15' M235i BSM Auto
Make sure to follow PTF directions and turn off Windows Defender firewalls on laptop, update BM3 agent and have it running in the background prior to attempting to connect, etc.
