04-04-2015, 10:05 AM | #24 |
Rep 886
LP, since we're talking track here, do you buy special HPDE insurance when you go out?
I have done a bunch of track days myself with the Mustang, and never insured it, but then again, it's a Mustang that's only worth about $12K now. I definitely want to track the M235i once it's broken in, but I'm seriously considering the HPDE insurance. BMWCCA offers single day coverage for about $300. Just wondering about your thoughts on that?
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
04-04-2015, 10:49 AM | #25 | |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
04-04-2015, 11:37 AM | #26 | |
Rep 886
http://locktonmotorsports.com/product/hpde-insurance
04-04-2015, 12:01 PM | #27 | |
Rep 845
That being said, it is definitely an option if you're feeling nervous. |
04-04-2015, 12:18 PM | #28 | |
Rep 886
- Shelby AC Cobra spin into a wall at Lime Rock, smashing in the front end, destroying the radiator, front suspension, and probably the frame, and being towed off the track. Probable total loss. Unbelievably, this was on the first lap of the first session! Tires were likely not warmed up. - Subaru BRZ spun off track and into guard rail at Lime Rock (not the same day as the Cobra). Wrecked the nose and looked like the front wheels were bent at a crazy angle. Probably not a total loss, but certainly over $10K in damage. - Porsche 928S blown engine on track at Thompson Speedway. Towed off track. - Evo IX spun off track and into guard rail at Lime Rock in wet conditions. This was a glancing blow to the rear quarter, and he was able to limp back to the pits without a tow. Trunk lid was popped open and could not be shut because of the damage. Certainly not totaled, but could have been $5-10K worth of fixes needed. So yes, only the Cobra here was definitely totaled, but still the other incidents were not something you want. I can only imagine the cost to fix an M235i if it were damaged like the BRZ. What would cost $10K to fix on a BRZ could be $20K on a BMW. You're absolutely right though that common sense should prevail, and usually does at these events. But as we saw in your previous video, spins do happen, and it's just a matter of luck whether your car is damaged or not.
04-04-2015, 01:11 PM | #29 |
Rep 4,528
Drives: M2 CS
Love the harness, well done
04-04-2015, 01:38 PM | #30 | |
Rep 146
Hope to get some feedback on sport mode stock vs H&R after you test it. |
04-04-2015, 03:28 PM | #32 |
Rep 845
04-04-2015, 09:03 PM | #33 | |
Rep 845
Also, with regard to liability insurance, I happen to be a lawyer when I am not hanging around here, and I can tell you right now that a lawsuit involving damage to a car on a racetrack would be laughed right out of any courtroom in the country. When you set foot on a racetrack, you assume the risk that your car might not make it through the day. Your car getting smashed up the racetrack is a risk that you take, and by participating in such an activity, you waive any right to sue because your car got smashed up. That's also why they have you sign that big waiver before they let you in the gate at any track. |
04-05-2015, 05:43 PM | #35 |
Rep 201
Great build! I am definitely getting that harness now that you've shown how to mount it. I'm interested in know if your diff is better or different that the M-Sport diff.
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
04-05-2015, 11:26 PM | #36 | |
Rep 845
Also, it's going to be a much more track focused setup with more lockup than the MP diff. |
04-06-2015, 03:55 AM | #37 |
Rep 201
Can you PM me info on your diff? I am pounding the snot out of mine too. Track event every month since I've had the car and no plans to stop. Thanks
04-06-2015, 11:17 AM | #38 | ||
Rep 845
I would not recommend doing this as a DIY. I would only do something regarding safety with an experienced mechanic. Also, it is very complicated. I will make a thread regarding how and where to drill for the anchor points with some better pictures, so you can show them to your own mechanic and have this installed. Quote:
Dan has not yet calculated the lockup percentages (the ramps still need to be cut and heat treated), but I think they will be around 40% for acceleration, and I am not sure about deceleration, but at very least it wont be less that 30%. Not sure though. I'll get back to you guys on that one once I find out more. The M-Performance Diff uses a 6 clutch carrier, which is nice, but generally much more fragile than the 3 clutch. Also, like I said, you can't change the oil on the MP Diff -- its a sealed unit. You can (and must) change the oil on the Diffsonline diff after 1200 miles (break-in -- just like an M Car), and then every other oil change after that. The oil weight for track use is 75w140 (Redline). If you do not intend to track your car ever, you can get away with 75w90 (Redline). Once I find out more, I will post. |
04-06-2015, 07:14 PM | #39 |
Rep 1,503
I'm in love with that harness setup!
Do you know if any of the 4 point harnesses made by Schroth will fit without having to cut anything? I'm very interested in the Scroth Quickfit |
04-06-2015, 07:22 PM | #40 |
Rep 845
I have no idea. I looked at that route before going for a more permanent fix, but Schroth said it would be another year before their F 2X solution came out. So, I just decided to take matters into my own hands and devise my own solution.
05-21-2015, 10:19 PM | #41 | |
Rep 957
Also be careful with the harness if you do not have a roll bar. If you roll the car, and the roof collapses the seats are designed to fold, the harness will prevent that, effectively crushing your skull or decapitaing you. |
05-04-2017, 03:34 AM | #42 | |
Rep 80
05-04-2017, 05:51 PM | #44 |
Rep 157
Great thread! I'll be tracking my M240i at least a few times (after I get it and put on some break-in miles) and there's some very useful info here.
What width/offset are your Arc-8s? Any rubbing with your setup? I've got a set (18x9 w/ 245/35-18 Conti ExtremeConatact DW tires) on my E46 325i and am extremely pleased with them. |
