03-26-2017, 03:32 PM | #89 |
Rep 5,369
Yes, the Dynojet will typically read 10% higher than a Mustang. And a Dynapack Dyno will typically read 10% higher than the Dynojet. It doesn't mean the numbers are wrong between these dynos, it's just the way the data gets reported.
03-26-2017, 03:53 PM | #90 |
Rep 28
So they are all accurate?
Three different dynos measure three different outputs on the same engine and they are all accurate? They just "report the numbers differently"?
So there is not way to accurately measure an engine's output? |
03-26-2017, 11:48 PM | #91 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Could always pull out the motor and measure it on an engine dyno at the crank.
03-27-2017, 09:52 AM | #92 | |
Rep 5,369
Dynojets are by far the most consistent dyno on the market in terms to spitting out numbers across machines. All a Dynojet does is the following: 1) Monitoring rpm throughout the run with an rpm pickup attached to a coil pack and spark plug wire. 2) Measures the time is takes to spin the weighted dyno drum compared to rpm. From this, the torque numbers are generated. 3) HP is then derived from the torque numbers through a basic equation. 4) The HP and torque numbers are then corrected to standard conditions. 5) Done. |
03-27-2017, 11:46 AM | #93 | |
Rep 966
That is true. But I think the typical discussion and this one at hand is when someone posts "I just dyno'd my car and it made 500WHP" As soon as someone asks what brand dyno this all comes about. Or that same person goes to a different brand dyno and it produces 15%-20% less power then the first dyno because its not a Dyno Jet or whatever was used... |
04-03-2017, 04:45 PM | #95 |
Rep 970
Okay, here we go.
Had my Stage 1 installed this morning. Traffic down here is still pretty bad (okay, really bad), cannot get on to a road where I'm not behind a construction truck or a "snowbird" going shopping or an "Early-bird special at Mel's Diner. That being the case, best I can is give first impression of tuner on the car w/ normal driving in "Comfort" w/ a couple of rolling accelerations from around 15 to 50 MPH. Something I have noticed w/ my M240i, when in "comfort" and just a normal acceleration from a stop, the car will hesitate just a bit before getting going. Not a '"stumble" or a "lag", just a little hesitation. When in sport or even Comfort w/ the transmission set to M/S, this hesitation is gone. So obviously, there is something in those setting that eliminates the car's hesitation from a stop. On the way to get the tuner installed I paid special attention to how the car performed with regular driving. Half throttle from a slow roll, etc. After getting the tune, I started the car and it idled smoothly and quietly. Shifting to "D", and applying some gas, that slight hesitation I noticed before was gone. Pulled into traffic from a dead stop, and again, no hesitation. So tuner must have adjusted something to eliminate that hesitation even when car is set to "comfort and "drive". This is a good thing Made a "U Turn" and went 1/2 pedal from about a 10 MPH roll and the car leapt forward. I was pretty surprised as I've done this before the tune and the car was pretty quick (again set to Comfort and tranny in "D"). However, with the tune, a very noticeable difference in acceleration and the way the car responded to the throttle. I mean very noticeable. I attempted to find some road where I didn't have someone in front of me where I could try "Sport" and D/S from a stop or a slow roll, but only time I had open road ahead of me was when I got around traffic and was doing the speed limit. Any hard acceleration could put me in jail or w/ a huge fine. So I will save further reports for a later date. All-in-all, tune is definitely noticeable even w/ the car set for "Comfort" and "Drive". In fact, a person could live w/ driving the car w/o "sport and "D/S" and still find the car to be plenty quick and responsive. Next time out will try some Interstate entrance ramp runs (providing I can find where I'm not behind a pick-up pulling a fifth-wheel back to Ohio or a dump truck loaded with fill for another Condo development going up). So far, as is, a big for the Dinan Elite tune. More will follow............................................ .. |
04-03-2017, 05:35 PM | #96 | |
Rep 558
Glad to hear that it is noticeable, even in comfort/drive. I also have that 'hesitation' you mention. Nice that the tune eliminates it! I share your traffic misery... Looking forward to hearing your impressions of Sport/Sport!
04-19-2017, 05:35 PM | #98 | |
Rep 970
Hard acceleration (again not WOT) and the car really bangs the gears. Its a transformed car w/ the Dinan Stage 1. Around town I can be over over 60 MPH in a a couple of heartbeats just playing around. Even in "Comfort: and "D" half pedal and the car flies. Sport mode / D/S and the car has a hair trigger. Touch the gas and the car responds. LOVE IT!!!!! Coming out of a 2015 C7, I'm not seeing much difference in around town acceleration (C7 is clocked a 0-60 3.9), can't believe my M240i isn't anymore than a tick or two slower with the Dinan.. Only thing missing is the Chevy's V8 rumble and roar. Actually not sure one can even utilize the extra power the Dinan provides over the stock B58 numbers (but I'm not bringing mine back anytime soon. ) |
04-19-2017, 05:59 PM | #99 | ||
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
04-20-2017, 07:31 PM | #100 |
Newer 2er
296
Rep 474
Will the Elite suppress a CEL from an after market DP?
04-26-2017, 07:18 AM | #102 |
Rep 554
Dinan_Engineering
Does the elite make any changes to the auto transmission shift programming? If not, is this something that might be coming out later? |
04-26-2017, 09:38 AM | #103 | |
Rep 3,128
That said, the ZF transmission is as close to perfect as I think you are going to get so I am curious as to what you would want to try and improve upon it. |
04-26-2017, 12:35 PM | #104 |
Rep 970
I have to agree. The transmission is pretty amazing. In D/S, the thing bangs gears like a stick and always grabs a lower gear on deceleration so you get engine braking or super quick throttle response. I find it to be flawless.
04-26-2017, 04:32 PM | #105 |
Rep 558
Agreed. I might even go so far as to say that's it's better than the DSG in my GTI, which I LOVE!.
04-26-2017, 04:58 PM | #106 |
Rep 623
04-26-2017, 11:15 PM | #107 | |
Rep 554
Finally... the automotive industry has created the perfect transmission. Lets put it in everything, forever. Think of the amount of money that will be saved not having to develop any more transmissions. Perfection has been achieved at last! I'm only joking of course. I was just curious if Dinan had anything up the sleeve on modifications to the trans software. I agree, excellent transmission. Thanks for the info. |
04-28-2017, 04:48 PM | #109 |
Mpbruin108
185
Rep 851
I know this might be an off topic question but what if I wanted to switch to E85 gas (with all the engine component upgrades too), can we program the Dinan Elite to work with E85 gas?
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539 Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s |
04-28-2017, 05:13 PM | #110 |
Rep 3,128
You can run E85 and the factory DME will adjust timing accordingly to some degree and yield a bit more power but the DINANTRONICS unit itself is not tuned to take full advantage of E85 fuel. Perhaps in the future but I think a race octane (100+) map is more likely to be entertained than an ethanol one.
