08-18-2016, 11:53 PM | #45 |
Rep 1,084
mine
08-19-2016, 11:26 AM | #47 |
Rep 129
Drives: 2016 MW M235xi
Quick question for anyone who knows. I'm planning on installing these today or tomorrow (along with ebc yellow brakes and etc 200 fluid) and was wondering how quickly I should get an alignment? Is it something that I need to do right after I install them or can I wait until Monday when all the shops open? Basically will driving 50 miles without a proper alignment hurt my car. Thanks!
08-19-2016, 11:30 AM | #48 |
Rep 1,084
you'll be fine for 50 miles, just set the camber close to stock until you get to the shop
gtmax50076.50 |
08-19-2016, 04:18 PM | #49 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
08-19-2016, 04:28 PM | #50 | |
Rep 1,084
LCAs and TSes: you need to drive directly and very carefully to the shop. Better still: have them installed at the alignment shop.
08-19-2016, 04:31 PM | #51 | |||
558
Rep 1,477
Drives: 335i
08-19-2016, 04:43 PM | #52 | ||
Rep 1,084
It's just something to note. By far the smallest compromise I'm making to be able to run 255 square. The biggest compromise (IMHO) is noisy camber plates.
08-19-2016, 09:10 PM | #53 | ||
558
Rep 1,477
Drives: 335i
I seem to remember that there was some other challenge associated with the TSs, though... something related to the headlight leveling sensors maybe? I don't recall...
08-19-2016, 10:55 PM | #54 | |
Rep 1,084
08-21-2016, 06:16 PM | #55 | |
Rep 85
Also by the time you paid for the LCA and TS you are in camber plate territory. Is the NVH that much higher with the plates? Are the advantages of the LCA and TS really only there in addition to plates? Cheers |
08-21-2016, 06:41 PM | #56 | |||
Rep 1,084
I haven't measured, but by the looks of it, zero. Quote:
The TSes are just required when doing LCAs. Don't do LCAs without TSes.
08-21-2016, 08:10 PM | #57 |
Rep 85
"jmwilson125
Lieutenant United_States 49 REP 409 POSTS Drives: 2016 M235i Join Date: Feb 2015 Location: Somerville, Ma iTrader: (0) Camber plates vs M4 LCA Hey guys, I have read that the M4 LCA's can you you roughly -1.7 front camber. They also push the wheel forward about an inch. My question is what would the performance/feel difference between -1.7 degrees from M4 LCA and a camber plate set to -1.7 degrees? I ask because I have heard the wheel fitment I want to run will rub with LCA's because of the 1" bump forward. Any insight?" granted this is heresay to start with. it was indicted here. In another post Pparana indicated getting back 1/4" leaving me with an uneducated impression of a remaining 3/4" forward. I cant seem to find an actual result vs stock. For aggressive street then is the LCA/TS the ideal over plates? Plates do seem cheaper and simpler in the grand scheme providing the Vorschlag plates come good. They seem to have all the boxes ticked. Appreciate the education I'm an aircraft mechanic and a former VW guy so BMW is new to me. |
08-21-2016, 08:43 PM | #58 | |
Rep 1,084
I wish I could give a definitive answer to the movement issue tonight. Next time I'm around my friends that are stock or with LCAs only, I'll see if I can get a measurement. I'll take a tape measure to O'fest
08-21-2016, 09:11 PM | #59 | |
Supreme Allied Commander
3841
Rep 54,349
Drives: F80 M3
The forward movement of wheel carrier does pose some issues. However, if clearance is not an issue, you have just gained some castor, which adds camber gain for the outside wheel while turning and promotes stability at speed. |
08-21-2016, 10:07 PM | #60 |
Rep 1,084
I've just gone out and measured my car, wheel center to wheel center: 106"
08-22-2016, 12:38 PM | #61 | |
Motorsports Engineer
46
Rep 95
How are you guys measuring torque on the locknuts on the mounting studs? Those are nylon insert nuts, which mess with the torque readings.
Jason McDaniel at Vorshlag
08-22-2016, 02:01 PM | #62 |
Rep 85
08-22-2016, 02:04 PM | #63 |
Rep 1,084
wikipedia lists the M235i wheelbase as 105.9", and the M2 wheelbase as 106"; I conclude that my front wheels are exactly where they'd be with the stock suspension arms
08-22-2016, 09:50 PM | #64 | |
Rep 957
For example, a Grade 5 1/4-28 bolt in tension lubricated zinc plating, with a torque of 10.5 lb. ft. produces a clamping load of 2,511 pounds. If we use a use a Nylock nut that takes 2 lb. ft. of torque to turn, then 2 lb. ft. of torque is used in turning the nut leaving only 8.5 lb. ft. for bolt tension. Our clamping load is reduced to 2,009 pounds. If, however, we take our original torque of 10.5 and add the 2 that the Nylock requires and set our torque wrench to 12.5, our clamp load is 2,511 pounds. The same as it was without the nylock. You can use your torque wrench to measure Nylock nut torque and then add this value to the bolt's required torque. Prevailing torque calculation should be done with your nut and your bolt using your thread lubricant. Published prevailing torque charts may give you an idea of how much torque is used up by the nut's locking feature, but in actual conditions, the results will vary. There is an interaction between the bolt threads, nut locking feature, and the thread lubricant (whether liquid or plating) that makes each prevailing torque calculation unique. |
Dog Face Pony Soldier9719.50 |
08-23-2016, 03:32 PM | #65 | |
Rep 85
So is the consensus of all this that for street, LCA and TS trumps plates due to lack of NVH and plates are the ideal for track due to adjustability? Due to ease of install and cost are plates still a viable street option? Cheers |
08-24-2016, 01:42 PM | #66 | |
Rep 845
