02-26-2019, 10:15 AM | #199 | |
Rep 823
02-26-2019, 01:01 PM | #200 |
Rep 3,842
The door seals do help with tire noise on rough surfaces and air noise at higher speeds. When I owned my M235i I didn't notice any difference in engine noise but now that I've installed them on my new M2 Competition with the S55 engine, I've noticed a difference. There is a small space between where the seal stops and when the upper door jam seal begins. I plugged up that space with a piece of aftermarket weather strip which has worked great.
Bosozoku693.50 |
02-26-2019, 03:23 PM | #201 |
Rep 45
03-02-2019, 01:37 PM | #203 |
Rep 6,033
Several did along these six pages, and heard a difference, yours truly included. Quick and cheap way to muffle tire/road noise...not wind.
03-02-2019, 03:33 PM | #204 |
Rep 3,842
03-07-2019, 09:49 AM | #205 |
Rep 45
So I decided to do this test and see if these seals actually reduce road / wind noise. Tests are done 4 days apart. This is not using professional equipment or on a closed course, but I tried duplicating as much as I can.
2016 M235 xDrive Coupe Weather / road condition- Sunny and dry Windows, sunroof / shade, ASD, Radio and HVAC are closed / off Phone mount location is at the right center air vent At highest gear (A/T) using cruise control Same stretch of roads, no lane changes, no loud semi near by 1.5 months old Michelin Pilot Sport A/S 3 Using Decibel X from Apple App Store (free version) Each recording is about 20 seconds. Before Install 45 mph- Avg. 79.6 dB / Max 83.7 dB 70 mph- Avg. 81.1 dB / Max 84.0 dB 90 mph- Avg. 84.8 dB / Max 88.6 dB After Install 45 mph- Avg. 79.6 dB / Max 83.9 dB 70 mph- Avg. 83.5 dB / Max 86.4 dB 90 mph- Avg. 85.6 dB / Max 88.4 dB Interesting notes: I listen to my music and my volume is at the last "t" in entertainment and at 65 mph I have an avg of 89.2 dB / Max 92.6 dB (which is louder than road noise anyways). All windows / sunroof open- 65 mph- avg. 99.5 dB / Max 105.1 This is maybe why BMW no longer put these seals in as there is no difference in noise reduction. I will be returning the seal to my local BMW Parts Department. |
03-07-2019, 10:10 AM | #206 | |
Rep 823
03-07-2019, 11:54 AM | #207 | |
Everyday I'm shuffling
449
Rep 1,098
04-11-2019, 11:02 PM | #209 |
Rep 43
Regarding the dB measurements, I just did a major soundproofing project https://www.2addicts.com/forums/show....php?t=1603280 and didn't notice any difference in dB, although the car is definitely quieter to my ears. I wouldn't expect such a small piece of foam to show a measurable difference in dB, although a change in frequency may be why people hear a difference. I believe this foam works but don't expect a huge difference, but it makes sense: add sound dampening-->get quieter.
04-11-2019, 11:34 PM | #211 | |
Rep 3,842
sensor read in an unscientific test. I have very good hearing and I can tell the difference. |
Poochie9104.50 Sportstick4654.00 |
04-12-2019, 07:58 AM | #212 | |
Rep 6,033
Relative to the part no longer being present in new production (as I read...I haven't checked), we don't know that BMW didn't find a more cost/labor efficient solution in production, ranging from application of more mastic spray in a wheel well to changing the compound spec for a tire relative to hardness, and the resulting noise, to reach a similar outcome. We just don't know. The stuffers had all the hallmarks of being a temporary fix.
AlpsRider2865.00 ferraricare55.00 |
04-12-2019, 11:45 AM | #213 |
Rep 3,842
"I also found that it was noticeably helpful specifically for tire noise. I didn't find an improvement for engine noise."
After installing the strips on my M235i I didn't notice much difference with engine noise either. It was mostly tire and some air noise. My new M2 Competition with the S55 has more mechanical noise coming from the engine. It loves to rev. Since my car is a 6MT I shift at a higher rpm than the auto tranny would do. So with my car the strips definitely reduce noise. The tire noise is more noticeable on rough roads that make the tires "sing." It is such an inexpensive mod, I don't understand what the big deal is. If nothing else it helps keep dirt from collecting inside the door around the hinges. Last edited by AlpsRider; 04-12-2019 at 12:36 PM.. |
04-12-2019, 01:46 PM | #214 |
Luxury at the redline :)
9105
Rep 7,563
The weather striping does make a difference. #Duh
Don't believe me? Rip a hole in any of the other door seals or slightly crack the window, then drive for like the 80mph; you'll hear the air rushing into the cabin. If it didn't serve a purpose, a penny-pinching company like BMW would of left it off on the 228/230 and all diesel motors. It was not added to the 235/M2 because BMW didn't want to cabin to sound too insulated for their "sportier" vehicles. Living proof that it does make a discernible difference, in place. |
04-12-2019, 04:02 PM | #215 |
Rep 204
I am wondering if they really didn't help why do some of the later model F22s have them installed. Is it the model year or do options make a difference? I'm not going to pull mine out to test it they make a difference.
04-15-2019, 07:27 PM | #217 | |
449
Rep 1,098
You got it all backwards. Being a penny-pinching company, BMW stopped installing these strips after they found (hopefully via scientific enough methods). That is proof that the strips don't do much, if anything. If BMW started installing these strips after a certain date, that would be the proof that you seek. It's not that BMW didn't want the cabin to sound too insulated. You do realize that the engine noise that you hear in the M2 is fake, piped in through the speakers, yes? No weather stripping would change any of that. |
04-16-2019, 12:48 AM | #218 | |
Rep 3,842
Poochie9104.50 |
04-16-2019, 08:53 AM | #219 | |
449
Rep 1,098
I refer you to my previous post. https://www.2addicts.com/forums/show...&postcount=197 |
04-16-2019, 09:36 AM | #220 | |
Rep 6,033
However, this extra part creates a burden...another part number to track, another supplier to manage or part count from an existing supplier, additional cost, additional labor op on the line where time/space must be allocated. All of these issues provide motivation to find a more efficient solution to the problem. As I suggested earlier, BMW, in the meanwhile, may have found another solution with other materials either in the structure/materials forward of the door opening (in/surrounding wheel well), a tire compound spec change to reduce noise, etc. After having demonstrated to themselves the value of the part which started the process to include it, the eventual disappearance is most likely due to finding a more effective solution. If it was proof of ineffectiveness, then you would have to indict BMW's engineering process which lead to creating and installing these parts in the first place. I do not have absolute proof, but as one from another OEM, I highly doubt that. The lack of benefit by some later model owners may just be evidence of BMW having found a more cost-effective solution to road noise.
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 04-16-2019 at 09:54 AM.. |
