2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Want to Protect the Door Panel
      01-28-2018, 07:12 PM   #1
Shovelman
Shovelman's Avatar
243
Drives: 2017 230i
I sit deep in the seat and I'm not real tall. My 2 door 2er makes me put the seat pretty far forward to let me put the clutch to the floor. In my garage I can only open the door one notch so it is tight getting out. I sometimes drag a foot on the door or the rocker panel. Any suggestions to protect these areas?
      01-28-2018, 07:39 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
One thing you can do is cut a pool noodle in half and glue it to the wall at the outer most height where the door touches the wall
Maybe that way you can open the door wider...
https://www.amazon.com/Pack-Extra-De.../dp/B01N69ON6S
      01-28-2018, 07:53 PM   #3
BEM-S4
BEM-S4's Avatar
Self adhesive - I have this very helpful.
Car Door Protector Bump Body Guard, 79" Length 8" Width Sectional Foam Sticking Garage Wall Parking Protector Collision Avoidance Waterproof Foam Prot https://www.amazon.com/dp/B073WWNHYB..._u1p6lKWZMBfat
      01-30-2018, 08:53 AM   #4
Maynard
Drives: 228iX & M2C
Set the second seat-setting button to be fully rearward; hit that as you power down and you'll have more room to maneuver. I just wipe my doorskins/sills w/ damp cloth now and then - don't think it has actually scratched anything. You can also use the 'wall-bumper technique noted above, but with a hanging pad if you are next to another car (hang it from ceiling at the right height, and it works for both cars - does take some practice to not get snagged in it (if you do this in an apartment carport, your neighbors may just tear it down if they don't get it).
BM235iW97.00
      01-30-2018, 09:21 AM   #5
Rayscott
Drives: BMW 228ix
I have one of these too. Also, I have my seat programmed on button 2 to go all the way back which gives me more room to get out of the car. And, if needed get one of those latch handles which come with a glass hammer and seat belt cutter. I'm 74 now no problem getting out but may need one in 10 years.
      01-31-2018, 04:21 PM   #6
Shovelman
Shovelman's Avatar
243
Drives: 2017 230i
Thanks Maynard
The hanging pad is a good idea.
Maynard3830.00
      02-13-2018, 03:07 AM   #7
msej449
msej449
msej449's Avatar
United Kingdom
514
I've taken a 2' length of ¾" water pipe insulation and hung it on the garage wall. This is the foam cover for metal water pipes that has a slit all along it so you just wrap the insulation over a pipe. Works very well with the longer doors on the 2 Series. I'll take a photo' later.
On my electric seats, there's a rocker switch on the top of the seat. Press-and-release it quickly, backwards, once, and the seat moves as far back as it can go; then press-and-release it forwards and it returns to the memory position. You do the converse to move it forwards the maximum. It isn't always obvious it can do this, as pressing for more than a second just moves the seat forwards/backwards while depressed.
2023 Peugeot e-208 GT (electric)
      02-13-2018, 05:46 AM   #8
Marmugmotleocay
Marmugmotleocay's Avatar
Drives: 2021 BMW X3M Competition
I use these. https://www.griotsgarage.com/product...fType=&from=fn
      02-13-2018, 09:52 PM   #9
Masterongear
Drives: 15 M235i Black Saph Metalic
I use cardboard from all the boxes I get from all the mod deliveries. It's free but does not look the best obviously.
      02-13-2018, 10:56 PM   #10
ggggbmw
Drives: 2017 M2 Manual
Cardboard works to prevent dents, but it is surprisingly rough. Almost like fine sandpaper. After 10 years of opening the door of my last car against a well placed box I was surprised to find that the paint on the door edge was wearing off. I'm being more careful with the new car, but need to find something better.
      02-14-2018, 11:15 AM   #11
samej
Drives: 2017 F22 M240i xDrive MG
I actually had my door edges wrapped when I put XPEL on on delivery as we have a car port with a brick wall that I (or more to the point my GF) occasionally tap on entry/exit. The wrapper did it for free as I'd wrapped pretty much the entire front. after some months it occurred to me I should have just wrapped the entire doors as door dings in parking lots are likely to be more of an issue long term.
2017 M240i xDrive Loaded
2013 328 xDrive Premium, Executive
2007 335i Premium
Denk1006.00
      02-14-2018, 11:39 AM   #12
mdputnam
mdputnam's Avatar
289
Perhaps a better approach would be to code your car for easy access.
With this activated the driver's seat will automatically move back to a predetermined position when you get out of the car and move forward to the original position after you get in the car. No more scuffs and it will be much easier to get in and out of the car under all conditions.
      02-14-2018, 02:19 PM   #13
samej
It's not the scuffs on the interior door panel but the edge of the door hitting the wall outside. If I park just right I'm about a half inch clear of the brick wall on the second door detent - and the door will hit if I let it swing. On the right side I'm less than a foot from the pole of my car port, with the mirrors folded. I trust the parking sensors a lot!
2007 335i Premium
      02-14-2018, 04:58 PM   #14
Shovelman
Shovelman's Avatar
243
Drives: 2017 230i
Actually my OP is about the inside of the door and the corner of the seat.
      02-22-2018, 08:38 PM   #15
r0nd3L
Drives: 135i
I coded my M235i to move seat back automatically after shutting down car and opening the door. Seat slides back into memory position when door is closed and I turn ignition on. Super convenient!
      02-22-2018, 09:31 PM   #16
Denk
Denk's Avatar
1006
Drives: 2021 X5M
Clear film paint protection. I had my hood, bumper, front fenders, door cups, side mirrors, rear bumper and...door edges protected with Suntek. Big fan, used on previous M3's, super chip protection. Just an awesome product!
Search this Thread:
