09-27-2016, 04:12 PM | #1 |
Rep 87
Unexpected Driving Mode Behaviors
I've noticed that the driving mode controls behave in two undocumented ways.
(1) A safety feature? The Sport (up) button must be pressed twice within about 3 seconds to switch from Sport mode to Sport+ mode . If you are already in Sport mode then pressing the Sport (up) button just once causes the word Sport to be displayed, but doesn't change the car to Sport+ mode. In effect, you need to double-press the Sport button, similar to double clicking a computer mouse button, to get to Sport+ mode. Attached below is a diagram that illustrates how the car responds to the Sport (up) and ECO PRO (down) buttons in changing among the four driving modes (which BMW calls “programs” in the manual). Granted, this is a small nuisance, hardly worth mentioning. I noticed it long ago and probably everyone knows about it already. I only include it here because it's not in the manual and I don't like it. A single press of the Sport (up) button should be sufficient. Why require a double press to enter Sport+? My guess is that someone at BMW felt that Sport+ mode should be a little more difficult to enter because it includes a partial disablement of the DSC safety feature (switching from full DSC to Traction mode). (2) A design bug? No matter what mode you are in, if you press the DSC OFF button (turning on Traction Control) then the next time you press the Sport (up) or ECO PRO (down) button the car will respond in an abnormal way. For example, suppose you are driving along in Sport mode and have pressed DSC OFF to enable TRACTION control. After a while you decide to change to Comfort mode, perhaps because you are approaching a bumpy stretch of road. You press the ECO PRO (down) button expecting the car to switch from Sport to Comfort, but instead it puts the car into ECO PRO mode! Similarly, if you are in Sport+ mode and press the DSC OFF button once or more times for any reason, then the next time you press ECO PRO (down) the car will jump all the way from Sport+ to ECO PRO mode! This must be a bug in the BMW software (the driving mode programs and the code that controls them). At least I cannot think of a reason why the designers would want the car to respond in this illogical way. Jumping from Sport+ to ECO PRO, skipping Sport and Comfort, can't be what they had in mind. Also, turning Traction Control on and off, as described in the manual, shouldn't change the meaning of pressing the Sport (up) or ECO PRO (down) buttons, even temporarily. These undocumented behaviors may exist in BMW models beyond the 2 series. Does your car do this too? |
09-27-2016, 04:53 PM | #2 |
Rep 5,364
Yes, my M235 does this. It's not a big deal either.
The likely reason they (meaning BMW's lawyers) want you to push the Sport button twice to engage Sport+ is to make sure that you want to do it. The reason being Sport+ dials back some of the stability control system and allows for some sliding which could catch a rookie off guard, especially if they're in the wet and mash the gas in a turn (i.e. Sport+ likely won't save you from that stupidity). As for the other characteristics you mention when pushing the ECO button, it's simply the logic BMW choose to go with. It restarts the driving mode process at the least aggressive setting. |
09-27-2016, 05:58 PM | #3 | |
Rep 87
The case I described, pressing DSC OFF while in Sport+ mode, turns Traction Control off, fully enabling DSC, making the car safer. So why then in this safer state would pressing ECO PRO (down) skip past Sport and Comfort modes? It's complicated. I drew a state diagram. Some states are unimportant. E.g., while you are in Sport+ mode you probably would not ever use DSC OFF to turn off Traction Control. Instead you would just drop down one level to Sport mode. The real world case that matters to me is the following: I've configured the Sport mode settings to have the Sport Chassis but the Comfort (linear) Drivetrain. In this customized Sport mode I turn Traction Control on using the DSC OFF button. Then some time later, down the road, I want to go to Comfort mode. I press ECO PRO (down) and the car skips Comfort mode, requiring me to press Sport to get to Comfort. The second behavior I described does not have a safety benefit. |
09-27-2016, 06:56 PM | #4 |
Rep 2,867
I think that when you hit DSC OFF it automatically puts you back into comfort mode, so from there, the button-down is eco, and button-up is sport.
And I think DSC is not really safer - it is the 'nannies-off' option; IMO better to use sport+, reduced but still with some safety (I know - tons of debate on this). I just saw somebody had a nice factory chart with how this sorted out, but DK where (will add that if I can find it). |
09-27-2016, 07:33 PM | #5 |
Rep 5,364
Sell the car?
It seems totally insignificant and it's an intentional design by BMW. Also any good driver would not be changing driving modes during aggressive driving manuvers thus there's no safety concern here. What frustrates me about driving modes is not having a Sport+ mode without the touchy throttle. I've got every other option. |
09-27-2016, 07:38 PM | #6 | |
Rep 518
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
09-28-2016, 08:41 AM | #8 |
Rep 222
http://www.babybmw.net/forum/viewtopic.php?f=74&t=71296
That would be me. Think of DSC Off as a 5th or 6th driving mode on the rocker button, not an adjustment within the rocker modes (eco up to S+). It's not intuitive but it's verily true. For the first gripe, go from comfort to S+ with 2 quick presses. Go from Sport to S+ with two quick presses. It's very clearly by design, just like cruise control kicks you out of S+. |
09-28-2016, 10:52 AM | #9 |
Rep 5,364
I want the Sport steering, the Sport suspension, and the Sport+ nanny reduction so that I can get some spin and sliding. There is no such setting on the car. You can adjust Sport to have the Sport suspension and steering, but all the nannies are turned on and in this car, those nannies work really hard to kill all evidence of wheel spin and sliding.
With the auto car, it's probably not a big deal, but with the manual cars, the Sport throttle setting can be a bit touchy and make leaving the line in 1st and the 1-2 shift a bit unsmooth. It's sometimes frustrating to those of us that have been driving manuals for years and have the ability to shift buttery smooth when we want to. |
Poboy9.50 |
09-28-2016, 12:02 PM | #10 | |
Rep 87
I can configure the Sport mode settings to have Sport Suspension with Comfort Drivetrain. Unfortunately, there is no way to turn on Traction Control while remaining in Sport mode. It's disappointing. BMW will let us use Traction Control in Sport+ or Comfort modes, but not in Sport mode. |
09-28-2016, 07:02 PM | #11 |
Rep 818
Just drive the damn car. I honestly cannot even comprehend everything you wrote because it's so far off.
DSC OFF means just that. Dynamic Stability Control is OFF. DSC encompasses stability AND traction control. No nannies. Go try your luck with this mode engaged, "RWD Drifter." TRACTION (one press of DSC button) or the "+" of Sport+ takes only stability control off, but leaves traction. So, the car lets you slide it out but won't let you roast the tires off sideways. It'll line you back up straight to continue on. Quit thinking too much into it. The car was designed to operate how it's operating. Drive it. |
09-28-2016, 07:25 PM | #12 | |
Rep 1,117
Drives: 2015 BMW M235i
09-28-2016, 10:05 PM | #13 | |
Rep 765
09-28-2016, 10:48 PM | #14 | |
Rep 393
Now, I just want to know if the DSC can be hacked.... Because I've read............... |
09-29-2016, 01:18 AM | #15 |
Rep 470
You're overthinking this.
Just think of comfort as the neutral mode. DSC OFF is essentially neutral mode throttle with sport chassis (and no nannies of course). So in that way, it makes sense when pressing either up or down will bring you to Sport or Eco.
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
09-29-2016, 04:31 AM | #16 | ||
Rep 886
TRACTION mode means that the traction control system setpoint is turned down, allowing some wheelspin, but not an unconstrained amount. Stability control remains active, but may allow slightly more yaw before intervening. The design thought behind this is a situation such as trying to get going in snow and not wanting the car to pull the power off just as the car gets moving if the wheels start to spin. Absolutely.
allthatisntnow377.00 |
09-29-2016, 07:09 PM | #17 |
Rep 2,867
09-30-2016, 04:47 AM | #19 |
Rep 886
That chart keeps getting posted, and it's not correct for a 2-series. It's from a 2014 335i that has both the uprated power kit and a performance exhaust. That particular combination differs from other 3-series cars, let alone the stock 2-series.
The chart is a hint, but it's not accurate for our cars.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 09-30-2016 at 10:18 AM.. |
amw896582.50 |
09-30-2016, 11:47 AM | #21 |
Rep 886
Yup. It is always active. However, since you can't spin the wheels in most modes without DSC's traction control function cutting power, people can't see it, so they don't believe it's there.
09-30-2016, 11:52 AM | #22 |
Rep 87
Wow! BMW apparently intended that the controls work this way!
All I wanted is Traction Control (aka DTC) with the Comfort Drivetrain and the Sport Chassis settings. That's not allowed. I can live without it. The manual should mention that pressing DSC Off activates or deactivates DTC and puts the car into Comfort mode. |
