04-25-2024, 07:37 AM | #1 |
Coder
574
Rep 1,550
Hey, I haven't posted in while but I am looking to upgrade my 2016 F82 OEM downpipes and mid-pipes with a high flow setup. Back in 2016-2017, I had catless downpipes but I had to revert that back and never got back to putting my catless back on after doing the first emissions.
This time around, in order to avoid that. I am thinking about getting the Active Autowerkes Catted GESI downpipes so that I don't have to deal with emissions testing in Virginia. I'm also thinking about upgrading my mid-pipes to either the AA High Flow Single or Equal Length. Leaning towards the Single. Currently I have my MPE exhaust that I am very happy with. As I understand, the stock MP has two secondary cats and a resonator. I shouldn't be expecting a CEL after swapping to AA MP? Appreciate any experience/advice. Thanks!
2016 ///M4: SO / SS — Lovin' it!
04-25-2024, 09:28 AM | #2 |
Rep 86
You can touch/remove resonators with no problems.
Only thing that throws a code is when you touch the Downpipes. If your tuned then that takes care of the CEL, if not tuned then Match schnell module or JB4 should solve it. |
04-25-2024, 09:31 AM | #3 | |
Coder
574
Rep 1,550
Do you think a resonator is needed or I'm good to go with non-res MP?
04-25-2024, 10:53 AM | #4 |
BimmerPost Supporting Vendor
24344
Rep 191,143
High flow catted + the single midpipe is an excellent option
i prefer the resonated midpipe for a cleaner sound, but either option would work
Jbonly211093.50 |
04-25-2024, 10:56 AM | #5 |
Coder
574
Rep 1,550
What difference will I be noticing with res and non-res?
04-25-2024, 11:13 AM | #7 |
Coder
574
Rep 1,550
Awesome! Looking forward to getting mines!
04-25-2024, 04:12 PM | #8 |
1964
Rep 5,017
I'd go with the midpipe alone and start there. Is there a reason you need to swap the factory dps other than sound?
04-25-2024, 04:30 PM | #9 |
Coder
574
Rep 1,550
Haha mostly sound. I miss my catless 😂
Info@mad-us.com1963.50 |
04-26-2024, 08:26 AM | #10 |
Rep 545
04-26-2024, 08:28 AM | #11 |
Coder
574
Rep 1,550
Would you suggest I go with resonators in case I decide to upgrade the downpipes down the line?
04-26-2024, 11:11 AM | #12 |
24344
Rep 191,143
s0ul574.00 |
04-26-2024, 04:05 PM | #14 |
Rep 545
04-26-2024, 04:07 PM | #15 |
Coder
574
Rep 1,550
Gotcha. However, the downpipes I mentioned are the High Flow CATTED downpipes from AA.
05-01-2024, 01:18 PM | #18 |
1964
Rep 5,017
Tough pill to swallow especially with the costs involved. If you're flashed you won't have any issues with a cel which is the main reason to go with the more expensive Gesi cats. Stick with the factory downpipes or go with a higher flow option and get the power as well.
05-01-2024, 01:21 PM | #19 | |
Coder
574
Rep 1,550
Currently I am running a JB4 Map 1. Will set it to Map2 with the GESI HF cats and single mid-pipes. I'm also on the fence if I want to get the MHD with JB4 BEF but I'm not certain yet.
