01-17-2023, 01:55 PM | #1 |
Rep 4
Weird noise coming from the top (passenger) of the engine block
Hello all,
I am new to the forum, so it's nice to meet everyone virtually. I have a 2018 M2 with 32K miles, and it's been amazing until recently. When idle, I started hearing a weird slow tapping/knocking noise coming from the top left (passenger side) of the engine. I haven't noticed any rattling when driving, nor does it affect any performance that I can tell. Please look at the video and listen to see if you have experienced it before and what the problem was. https://youtube.com/shorts/9FPncAJZnxQ I appreciate any help you can provide. Last edited by htt77; 01-17-2023 at 04:22 PM.. |
01-22-2023, 09:35 PM | #2 |
Rep 7,433
Oh man that doesn't sound reassuring.
Do you have any codes?
01-29-2023, 03:34 PM | #4 |
Rep 75
It's not the exact same cause, because my noise sounded different and was on the driver side, but I had a vacuum hose start to come loose which resulted in a weird noise that was kind of similar. The cause was a plastic fitting that was literally crumbling away due to heat. No code appeared but I'm sure it would have eventually popped up if I had let the issue progress.
I would poke around the engine bay with a flashlight while the car is running. You may find something similar. |
F87source7255.00 |
02-17-2023, 12:37 PM | #5 | |
Rep 4
02-27-2023, 01:14 PM | #7 |
Rep 4
man,you are awesome! I poked around wastegate rattle and this is the exact sound I hear from the car https://www.youtube.com/shorts/SuqgxJAtM2c
the question is: how do I fix it? is it a simple replacing of the wastegate or from reading, I may have to replace the turbo all together. |
///MPhatic13864.00 |
02-27-2023, 01:44 PM | #8 | |
The Seeker
13864
Rep 3,322
Hopefully you can get help from something there. It's a common issue so there has to be a fix. |
