06-20-2023, 01:33 PM | #1 |
Rep 4
Rear Left Turn Signal Malfunction.
Hey guys, I recently got this error on my 19' M2C. I parsed through the forum and see people are saying
1. Lack of ground for LCI tailights(?) 2. Relay issue(?) 3. Software Issue(?) I do not think its a Software related issue but who knows? Maybe BMW Engineers use spaghetti code. Please advise on what to do next! I believe replacing the light is a band aid fix. Thanks! |
06-20-2023, 01:49 PM | #2 |
Rep 6,979
Drives: 2018 M2 AW DCT
I have been told that BMW now warrantees the taillights for 7 years or 100,000 miles. I would let BMW Service fix the problem.
BMWCCA member Puget Sound Chapter
06-20-2023, 01:57 PM | #3 | |
The Seeker
14160
Rep 3,416
I had the problem with my right side (condensation as well), BMW replaced the entire light under warranty, no more issues, but IIR I've heard of some people having issues even after full light replacement. |
06-20-2023, 02:25 PM | #4 | |
Rep 4
Check reply 193 https://f87.bimmerpost.com/forums/sh...1518790&page=9 But idk.. LED's do not get as warm as Halogens.. So maybe not? But idk. Potentially, BMW knows this might be this issue, but refuses to acknowledge it as Software Updates might have a lot of red tape. But idk haha. Possible that they fixed this in the new M2s |
06-20-2023, 02:29 PM | #5 |
Rep 4
I got mine used.. Is it a fair assessment that I should just call BMW give them my VIN and ask if I have the taillights warranty? Or is that something that I must buy separately
06-20-2023, 09:09 PM | #6 |
Rep 7,340
There are many threads on this issue but I will save everyone some breath:
1. There is apparently an extended warranty for all tails for LCI 2 series. 2. The coding to disable bulb check is NOT a complete fix, but it can buy you a lot of time before replacement is needed. 3. No one knows the exact root cause, but replacement of the tails does fix the issue. However, since all the lights become defective over time, it will just happen again. |
06-20-2023, 11:45 PM | #7 |
Rep 578
Where have you read this?
My cars: http://WWW.GARAGET.ORG/PHILLY
///M TOWN22103.00 |
06-21-2023, 06:34 PM | #8 |
Rep 1,018
I glad to hear the news about the warranty. I’ll have to look into it. I hope the BMW service departments know about this issue by now. I told them about this a few years back, and they didn’t seem to have a clue about it, and said it might be my add ons causing it (radar detector and dash cams).
This is a clear factual issue, but the frustrating part is they don’t seem to take it seriously if you tell them you read it on a forum (this goes for othe car manufacturers as well). |
06-21-2023, 07:12 PM | #9 |
Rep 432
Drives: F87 M2 DCT, F15 X5
My right rear tail light will occasionally show a fault and not flash. It will only last for a few minutes, then the fault clears. Annoying!
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
06-21-2023, 08:09 PM | #10 |
Rep 507
Drives: 2018 M2 6MT
I first read about the 10-year warranty on the rear signal housings in this thread here on BIMMERPOST:
https://www.bimmerpost.com/forums/sh...php?p=30028188 I’ve since read about it in a few other threads, so it seems to be a real thing. I’d love to see some sort of TSB or other official documentation about it. For now, it seems to be the stuff of whispers, hopes, and a good relationship with your SA. |
chris7197392.00 |
06-22-2023, 03:16 PM | #11 |
Rep 432
https://static.nhtsa.gov/odi/tsbs/20...71414-9999.pdf
This does not have to do with the turn signal malfunction.
‘18 F87 M2 DCT
07-17-2023, 12:07 PM | #12 |
Rep 1,821
go to http://bmw-rp.com put your VIN in there. Mine had a Rear Panel Light or something like that there. The dealer also has this info.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
07-18-2023, 04:15 AM | #13 | |
Rep 10
07-20-2023, 04:19 AM | #14 |
Rep 166
Just scrolled several threads on this issue and can’t find a definitive answer ….
Does this rear light issue potentially affect all (F87) M2 and M2Cs, or just certain years? Seems to be more common on the earlier years. I can’t find a ‘21 that had this problem, but maybe I didn’t look hard enough. |
07-20-2023, 08:51 AM | #15 | |
Rep 6,979
Swish77381.50 |
07-20-2023, 12:38 PM | #16 |
Rep 320
Anyone have the documentation stating that these are to be replaced under warranty. I told my local service manager(where I bought thecar) about this and they played dumb and wanted 800+ to replace the tailight assembly
07-28-2023, 09:40 PM | #18 |
Rep 6,979
I understand there is a service bulletin that covers the taillights.
05-03-2024, 03:57 PM | #19 |
Rep 507
Drives: 2018 M2 6MT
I’ve recently learned that FCP Euro is now carrying the LCI/M2C rear light assemblies. Yes! That means this problem is now effectively covered by FCP’s lifetime guarantee.
Left assembly: https://www.fcpeuro.com/products/bmw...mw-63217420993 Right assembly: https://www.fcpeuro.com/products/bmw...mw-63217420994 |
///M TOWN22103.00 |
05-06-2024, 08:01 AM | #20 | |
Rep 185
05-06-2024, 09:14 AM | #21 | |
Rep 507
Drives: 2018 M2 6MT
I see different part numbers for the Euro-spec tails with amber turn signals: https://www.2addicts.com/forums/show....php?t=1405431 I don’t know where the Euro-spec tails might be available. |
05-13-2024, 02:49 PM | #22 |
Rep 444
I’m assuming that the lights are only covered by a warranty if you actually have an existing BMW warranty? It’s not actually a recall as such?
My left does this pretty regularly and the right hand indicator does it but very rarely. I’m in the U.K. and mine is a 2018 LCI as well if it makes any difference |
