01-23-2016, 08:33 AM | #23 | |
Rep 241
01-23-2016, 10:32 AM | #24 | |
Rep 5,262
Automatic Differential Brake (only active in DSC mode off turned off) they even mentioned twice |
01-23-2016, 12:58 PM | #25 | |
Rep 886
In both DSC modes (fully on and partially on), the system provides both differential braking and either power pull off at incipient wheel spin (DSC ON) or after a limited amount of wheel spin (DTC). If DSC is fully off, then ADB mode is on. BMW's corporate site goes into more detail at http://www.bmw.com/com/en/insights/t...erential_brake. Note that ADB is explicitly called out as a part of DSC. BMW's Dynamic Stability Control (DSC) system ensures that the vehicle remains stable when taking bends, speeding up or braking on uneven road surfaces or in poor driving conditions. The Automatic Differential Brake (ADB-X) is part of this system. Using sophisticated electronics, it offers the same function as a mechanical differential brake - without any disadvantages arising from weight and loss of efficiency.The full table section showing this from the reference you provided is shown below.
01-23-2016, 02:05 PM | #26 | |
Rep 5,262
Correct... If DSC is fully off, then ADB is on, so then when you are not in DSC OFF, ADB is off like it shows on the table It can't be more clear than that, ADB is only active in DSC OFF mode |
01-23-2016, 05:26 PM | #27 |
Rep 228
You guys scared me so now i dont turn off dsc. Just drive in sport and call it a day
OldCrow7xx72.50 |
01-23-2016, 05:46 PM | #28 | |
Rep 3,842
I agree learning to control a car is valuable and it is impossible to really get a feeling for a car and unless you know how it behaves when it slides around a corner. Last edited by AlpsRider; 01-23-2016 at 05:54 PM.. |
01-23-2016, 07:21 PM | #29 | |
Rep 886
No. ADB is an included subset of DSC. Go back to this link http://www.bmw.com/com/en/insights/t...erential_brake and read it again. What part of BMW's Dynamic Stability Control (DSC) system ensures that the vehicle remains stable when taking bends, speeding up or braking on uneven road surfaces or in poor driving conditions. The Automatic Differential Brake (ADB-X) is part of this system. ...... If a wheel threatens to slip, it is individually braked: blocking momentum is directed to the wheel opposite, which thereby guarantees optimum drive power. When DSC or Dynamic Traction Control (DTC) is active, the engine power output is also adjusted.is confusing you? The "eDiff" function is always on, in DSC, DTC, and ADB. It's the only function on in ADB, and one of several in DSC and DTC.
01-23-2016, 08:49 PM | #30 |
Rep 1,124
[QUOTE=Zooks527]I concur.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
01-23-2016, 09:50 PM | #31 | |
Rep 470
This is a well balanced car and it is truly "user error" that would contribute to any instability. Use good judgment and common sense (which should be the case regardless), and there won't be a problem, DSC on or off. I like DSC OFF because of the sports chassis / steering / exhaust it provides without the aggressive throttle.
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
MassNerd171.00 |
01-23-2016, 11:03 PM | #32 | |
Rep 5,262
Cause it says it pretty clear twice... ADB inactive in DSC ON and DTC and again explicitly (ADB only active in DSC OFF) you are saying the technical doc is wrong then, cause you said "DSC on or off has no effect on the differential braking feature of the traction control system" Last edited by pikcachu; 01-23-2016 at 11:13 PM.. |
01-24-2016, 03:55 AM | #33 | |
Rep 886
You want to claim ADB isn't part of DSC regardless of what BMW's website says? Fine. Who cares, since that isn't the point in dispute ("When is eDiff on?")? You'll note that the chart above states that in both DSC and DTC modes, Automatic Stability Control is active. What is Automatic Stability Control? Again, per BMW (http://www.bmw.com/com/en/insights/t...lity_control): Automatic Stability Control (ASC) is an element of the Dynamic Stability Control (DSC) system. It prevents loss of traction on the drive wheels when setting off, when accelerating out of curves and in other critical moments. When one wheel has good traction but the other is on a slippery patch of road, the wheel with less traction is braked until it is again able to gain a grip on the road surface.Bottom line is that "eDiff " is on all the time. You're just obsessing over what the control function is being called. It also isn't hard to prove. Go out on a slippery surface (plenty of that in half the country) and try to get one wheel to spin faster than the one on the other side of the axle. You can't, as the car will differentially brake all the time. It's one of the parts of the stability control functions that can't be turned off, excluding cases where the car determines that the brakes are overheating.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-24-2016 at 04:54 AM.. |
01-24-2016, 11:35 AM | #34 | |
Rep 5,262
"When you keep holding it for 5 seconds DSC is deactivated and the system will not intervene to try and stabilize the car" with DSC OFF the only thing you get is the eLSD which will brake the inside wheel when turning to transfer torque to the outside wheel and let you accelerate faster I does make sense that DSC can brake individual wheels at all modes but its very confusing that the technical doc that you would think more accurate than a marketing snippet of a website shows like the function is only active on DSC OFF even though in reality it would be active in all modes I don't quite agree with "DSC on or off has no effect on the differential braking feature of the traction control system." though, in DSC ON or DTC the car will cut power and thus potentially correct the situation before the brakes need to be applied... so it has an effect in the sense that the feature will not kick in as often meaning on DSC ON or DTC, differential braking will not be applied as often as with DSC OFF |
OldCrow7xx72.50 |
01-24-2016, 03:05 PM | #35 | ||
Rep 886
OldCrow7xx72.50 |
01-24-2016, 04:31 PM | #36 |
Rep 1,931
Anyone else feel when all the electronic nannies are off its slower than just being in Sport+?
Try holding it down for 5 seconds till its off. Than if you go to put it into Sport+ you have to go 2 steps. It feels like its in Comfort mode without DSC/DCT on. Is this just me?
www.nybmwcca.org
01-24-2016, 07:54 PM | #37 | |
Rep 5,262
OldCrow7xx72.50 MassNerd171.00 |
01-24-2016, 09:00 PM | #38 | |
Rep 228
Thats exactly why im hooked now. Perfect for day to day drive. throttle in sport is a bit too much for traffic driving
05-18-2020, 12:26 PM | #39 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
Too many options
How should I calibrate my car if I want the following parameters: -Very heavy steering, I do not want the car moving unless I force the wheel hard. I have a very heavy hand and do not like then the steering is so light and floaty. When I put the car on "eco mode" I feel like 1mm of turn on the steering wheel and the car is veering off the highway. -I want the hardest suspension settings, I want the car to cut and corner on a blade, I do not care about ride quality. I just want fun and responsiveness. I am coming from a K20 Civic Si that cornered on rails. -I want the throttle to be as responsive as possible, often times in this car I feel like I have to go to 80% pedal or more to get the thing to wake up and respond to me. Again the civic felt so eager to rev and respond to my input, I just want this car to listen to me that way again. -I want the wheels to be able to spin, but have that final safety net as I learn to slide and drift my first high power RWD car. I want to be able to break traction and see the power I have forced the engine to produce is existing. Thanks in advance, this thread has already helped me more than anything in the past 3 months. Cheers
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
05-18-2020, 12:39 PM | #40 |
Rep 3,497
05-18-2020, 01:11 PM | #41 |
Rep 439
No I used the X-Delete software to convert it, hence the sudden need to understand all of this stuff.
dradernh4413.00 |
05-18-2020, 03:39 PM | #42 |
Rep 1,602
Find yourself an empty parking lot, preferably in the rain to practice correcting oversteer without over correcting. I grew up with a love for drifting but despite knowing exactly what was going on intellectually the first time I got sideways in a car, I still spun it simply because the muscle memory wasn’t there. You have to build that memory with practice.
I’m older now and no longer really that into drifting, but on both the street and the track (where I participate in endurance racing) I’ve had cars pop sideways on me mid-corner quickly and unexpectedly. But in those situations, I’m already correcting the slide before the conscious part of my brain even knows what’s happening. So do yourself a favor and build that muscle memory in a safe environment. |
OldCrow7xx72.50 |
05-18-2020, 04:12 PM | #43 |
Rep 2,873
The only safe environment is on a track at an HPDE. And 'safe' means all you lose is the money for bodywork. These quick 'how-to-drift' comments don't even discuss throttle-lift OS, which is the typical snafu for newbies. You can develop much of this feel with extensive winter driving, but it is really irresponsible to encourage somebody new to try to develop a feel for correcting a slide on the street (and IIRC, Porsche would have given their first born for 320hp in a 944 - I think those were 930 numbers, and that was widely regarded as a death trap).
And if there is any aspect of these cars that is NOT "clear as it can be" it has to be this nomenclature - the use of double negatives, undefined acronyms, and german grammar all had me completely confused until I found more details like are provided above (guess it would have been just too simple to call it 'limited-DSC' instead of 'DTC'? Or using 'traction' for the mode that ISN'T DSC?). |
05-18-2020, 05:05 PM | #44 |
Rep 204
So many posts already. All I was going to say is that (okay I'll admit it I am almost an old fart) even with my track experience unless I intended to race, then sports + works just fine for me. I can still swing the rear end around, but there is a bit of a safety net still there.
One comment for Maynard: I owned a 944 Turbo in 1985 and thought I knew how to drive having taken a Bob Bondurant class. What did that car produce then, what 210 HP, and a 3 second turbo lag. Anyway, punched it hard coming home and without nannies which didn't exist then hit the curb while setting up for a left hand turn. Lesson learned! Learn your car first in EVERY mode it provides and then have some fun, but be a little modest on public roads. |
OldCrow7xx72.50 |
