05-23-2015, 11:41 PM | #1 |
Rep 36
Tone Control Setting-Standard Radio
You may have figured this out already, but it took me some months to discover it. Since this procedure isn't in my Nav /Entertainment manual, here it is:
-Navigate to the tone control menu with iDrive. -Select the function (bass, treble, balance, etc.) you wish to change by rotating the iDrive knob. Press the knob down. The slider turns red. -Slide your finger laterally across the touchpad to set the slider to the desired level. You can hear the sound change as you move the slider. -To lock your setting in, press the knob down without touching the surface of the touchpad. The slider turns gray again, and you're finished. I think only BMW could make such a fundamentally simple procedure so complex and un-intuitive, then omit it from the manual! -K. |
05-24-2015, 04:11 PM | #5 |
Rep 36
Using the knob to set the slider results in the slider moving around randomly for me. Using the touchpad gives a precise setting for the function you're adjusting.
Using the shortcut is a good idea, since we have so many. -K. |
