02-12-2016, 07:17 PM | #1 |
Rep 78
Speedometer show in MFD
The salesman could not make the display behind steering wheel show speed. It shows trip distance etc but unlike a lot of other vehicles, it did show a digital speed readout. Is this possible? Thanks!
02-12-2016, 07:26 PM | #4 | |
Rep 116
http://www.2addicts.com/forums/showthread.php?t=997749 Last edited by Thebush121; 02-12-2016 at 07:38 PM.. |
02-13-2016, 01:52 AM | #5 |
Rep 78
Thanks!
I found vagcom easy to use on VWs. Is this easy as well? At first glance it seems a bit more confusing. Also vagcom was simply the cable and software. This seems like there are a couple addtnl pieces to make this work. |
02-13-2016, 04:24 AM | #6 |
Rep 886
You can see if it's in the diagnostic menu, but that's a PITA to pull up every time.
FWIW, GEorge
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 02-13-2016 at 04:31 AM.. |
02-13-2016, 11:49 AM | #7 | |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
A reliable and thrustworty source of the application/data you need would be shawnsheridan.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
