02-09-2016, 01:15 AM | #1 |
TeQuiero
85
Rep 424
Proper Jacking Point M235i?
Hi,
Does anyone know what the proper jacking point for the M235i is, or if there's a diagram of the underbelly of the F22 platform that I can refer to? Also, for the jack stand points beneath the side skirts, should I use BMW jack adapter or would regular jack stand be ok and won't damage them? Thanks! |
02-09-2016, 10:20 AM | #2 |
Rep 147
http://www.2addicts.com/forums/showthread.php?t=1133432
The link above shows a user's pictures of a spot toward the front-center of the car that a BMW shop foreman marked as a jacking point; I haven't used it myself. http://www.2addicts.com/forums/showthread.php?t=1053757 According to this link, you can use the rear differential to lift the rear. I haven't tried this either. I personally used a BMS jack adapter with my jack, which I used with the points underneath the side skirts that you mentioned. It's only $10-20, which is worth it for me. Others have reported using hockey pucks with just as much success. In terms of jack stands, I've seen users' pictures here where they used regular jack stands without special adapters just fine. I personally have 4 ESCO low-profile jack stands, which you can find below: http://www.reverselogic.us/jack-stands.html They're a bit pricey, but I couldn't find another stand that had flat contact surfaces. You can also get these stands with built-in pivoting blocks to plug in nicely to the side-skirt jack points, but I didn't opt for them myself. Maybe others can chime in with first-hand experience of using something other than the side-skirt jack points to jack up the car.
2016 M235i | Estoril Blue | Coral Red | 6MT
Tech | Cold Weather | Driver Assistance | HK M Perf. Gear Shift Knob, Parking Brake, Pedals, Carbon Interior M Perf. Black Grilles | CF Mirror Caps, Rear Spoiler, Rear Diffuser | Lightweight Front Lip Spoiler | M Perf. Exhaust |
02-09-2016, 10:40 AM | #3 |
Rep 8,942
Good luck if you've got a flat on the front. When I blew a winter tire I had to grab the wheel well and lift the car up as much as I could so the roadside assistance guy could get a jack under the car.
02-09-2016, 10:54 AM | #4 |
Rep 229
I've been under the car, and did not see a single location up front that looked suitable for use as a central jacking point. Looks like these cars were made for lifts only.
Have not tried jacking by the side skirts next to the jack pads. I have not seen enough evidence that these areas will support weight without deforming to convince me to try it. On the plus side, jacking under the rear jack pad does raise the front on the same side pretty easily. If a jack has enough lift, you should be able to raise the front enough to place a jack stand under it. |
02-12-2016, 07:11 AM | #7 |
Rep 7
has anyone ordered a spare tire and jack kit from bimmerzone? I was going to order one, but am now wondering if the jack will even work on the m235i.
02-12-2016, 09:20 AM | #8 | |
Rep 8,942
