02-14-2016, 01:45 AM | #89 |
Rep 5,262
02-14-2016, 07:57 AM | #90 |
Rep 886
Much money. Yuuuuuuge amounts of money. So much it would even make The Donald's hair move.
02-14-2016, 09:18 AM | #91 |
Rep 1,202
Not to keep beating this dead horse, but wouldn't you have to force the transmission into 2nd from 3rd at higher speeds? Aren't the syncros made to stop this kind of shifting? I've never driven a car that won't just grind and bounce out of 2nd if accidentally selected from 3rd under hard acceleration.
02-14-2016, 09:23 AM | #92 |
Rep 2,067
I'll admit that I don't know sheit from shinola about MTs (other than driving them in my youth), but much of these vehicles are already under computerized nanny controls so I'm kinda surprised that manufacturers haven't been able to figure out how to electronically lock out lower gear selections if it detects a potential over rev situation..
2019 X2
02-14-2016, 09:57 AM | #93 | |
Rep 195
Last edited by pjohns21; 02-15-2016 at 02:16 PM.. Reason: Not as angry as before... |
02-14-2016, 12:00 PM | #94 | |
Rep 3,331
If your shifter was electronically controlled, then yes, you could physically lock out a gear. As someone mentioned, starting with the C5 Corvettes, GM instituted a shifter "lockout" solenoid that would physically force you to skip shift from 1st gear to 4th gear under low throttle. Because the gearing was so long and the engine had so much torque, it was a way for them to get better fuel ratings. I had one, and one of the most popular first mods for the car was to electrically bypass that solenoid so that it wouldn't interfere with your driving. Technically you could design a system that controlled every single gate, however it would be expensive, convoluted, and as soon as any part of it failed, it would prevent the car from being safely drivable - that's why no one has done it. It's not some evil BMW plan. The reality is, most people will go on their entire lives without ever having made a money shift. But sometimes, shit happens. Syncros SHOULD keep the car from entering a lower gear at high RPM, but syncros are "suggestive" - and if you are going to slam a gear there is always a chance to bypass the syncros and get it in gear when it isn't supposed to. It's especially common when trying to drive fast, because in order to reduce your shift time you want to slam the car into the next gear as quickly as possible, which means you are forcing the lever rather than letting it slowly release and pop into the next gear, which normally requires very little force.
Current: '20 X5, '18 M3 ZCP
