01-14-2016, 07:44 PM | #23 |
Resident BMW Fanboy
259
Rep 866
I think i've figured it out.
335i comes from the factory with all-season tires with a higher treadwear rating (lower rolling resistance) where as the M235i comes with summer Pilot Super Sports unless someone goes for the all-season option. That's the only thing that makes sense to me.
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
01-14-2016, 08:04 PM | #24 | |
Rep 3,331
Having come from a F30 335i with the factory summer RFT's, I definitely observed 1-2mpg better consistently over the ~45k I had the car for compared to my 235 on the same commute (with All seasons RFT's). The F30 has a larger rolling diameter compared to the 335. (225/45/18 vs 225/40/18) - that equates to around a 4% lower rolling diameter. That gives you an easy 1+mpg right there, combine it with the slightly more aggressive PPK tune and you've got your delta. My daily commute sees about 24-25mpg in the 235 and saw 26-27mpg in the 335. Edit: Lol I already gave this answer 10 posts up.
Current: '20 X5, '18 M3 ZCP
01-14-2016, 08:23 PM | #26 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
01-14-2016, 08:45 PM | #27 | |
Resident BMW Fanboy
259
Rep 866
01-15-2016, 07:21 PM | #28 | |
Rep 3,331
The E9x uses the same wheel size as the F2x, not the slightly taller wheel found on the F30. Perhaps someone could throw some physics at it to prove me wrong with the calculations that the higher rotational mass of the wheel cancels out the larger rolling diameter benefit, but it seems like that's a pretty decent place to start when the rest of the driveline is virtually identical.
01-16-2016, 09:57 PM | #29 | ||
Rep 1,124
02-12-2016, 12:42 AM | #30 | ||
Rep 1,124
