01-02-2017, 06:39 PM | #23 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
01-02-2017, 06:40 PM | #24 |
Rep 1,124
I hear you, but why?
01-02-2017, 07:35 PM | #26 |
Rep 1,124
Thank you!!
01-03-2017, 09:40 AM | #27 |
Rep 2,214
I didn't think these cars has TPMS sensors anymore. I know they use the wheel speed sensors now (not as effective but no more sensors), or at least that's how my '15 is setup in Canada..
Is there a split or year where they stopped using the sensors themselves?
01-03-2017, 10:09 PM | #28 |
Rep 628
It's totally normal. Mine reads high on one side and then higher on the other. I'm not sure what the purpose of temp measure is anyway. I don't trust the readings anyway. Even when it comes to pressure readings I use my handy digital tire gauge every few weeks and adjust the pressure as needed. This is an example of over engineering IMHO.
01-04-2017, 05:04 PM | #29 |
Rep 1,219
Drives: 2015 M235ix
TPMS still used here in US, on both my 2105 M235iX and my wife's 2016 X3.
I scoffed at OP's claim until this morning, when I checked tire pressure and temp. Lo and behold, driver's front tire is consistently 2 degrees F higher than the others, which are all the same! |
rich8566608.50 |
01-04-2017, 07:17 PM | #30 |
Rep 89
My pressures are always pretty similar but my temps are always also higher on the same side. I honestly chalked it up to that being the sunny side while my car is parked at work.
I don't worry about it to much since I always wondered how accurate those are to begin with. |
01-04-2017, 09:19 PM | #32 |
Rep 1,124
You are correct - OEM from the factory. I had coding done that displays individual tire pressures and tires temps.
01-04-2017, 09:22 PM | #33 | |
Rep 1,124
01-04-2017, 09:24 PM | #34 |
Rep 1,124
On the contrary - I coded my 2014 235i to display the tire temp and pressures.
01-04-2017, 11:09 PM | #35 |
Rep 5,369
My tire temps vary from 2 to 3 degrees on either side with the drivers side typically having the lower reading. We're talking a 2% to 6% difference in reading on a relatively cheap sensor and that's the easy answer. I wouldn't worry about it.
doccyber258.50 |
01-05-2017, 09:37 AM | #36 |
Kingslayer
411
Rep 1,479
Plain and simple it has to do with weight and braking. Brakes on most vehicles are larger in the front as the front wheels do most of the braking. Weight is transferred rear to front when braking adding heat to the tires and brakes. With a driver in the car most of the weight is on the left front. Combine this with the fact that the LF wheel is closest to the brake master cylinder and you have the reason for higher temps on the LF. The distance from the master cylinder is shortest from the master to the LF wheel. When applying the breaks fluid reaches the LF wheel first - did you ever notice how the LF wheel tends to be the dirtiest?
Viffermike1753.00 |
01-05-2017, 11:08 AM | #37 |
Rep 1,219
Drives: 2015 M235ix
Great response! I believe you. All these factors (front weight, driver weight, distance from master cylinder) make perfect sense.
Thank you for a very elucidating post. |
01-05-2017, 05:57 PM | #38 | |
Rep 744
rich8566608.50 |
01-05-2017, 08:18 PM | #39 | ||
Kingslayer
411
Rep 1,479
01-05-2017, 09:17 PM | #40 |
Rep 1,124
I hear you but my left front is consistently 10% hotter than the right front tire.
01-05-2017, 09:18 PM | #41 | |
Rep 1,124
01-09-2017, 11:44 AM | #42 |
Rep 222
My front left is always warmer too, but only since I replaced that tire (nail in the sidewall). Makes sense to me in my case as that tire is newer and grippier. Had never been an issue before.
01-09-2017, 12:39 PM | #43 | |
Rep 2,873
I don't think that the different distance from master cylinder has a measurable effect on timing of the brakes - I think they move at essentially the same time, otherwise you would consistently pull to the left each time you applied brakes. Surely would not be uneven enough to notice in brake dusting or pad wear, or else you would certainly feel a consistent pull (i.e. even if there is something to this, the engineers must have found a workaround). |
01-10-2017, 09:35 AM | #44 |
Rep 556
Well, you could eliminate a few of these suggested problems by swapping the front wheels temporally to see if the off reading follows the wheel or stays on the same side. If it follows the wheel it's a sensor or tire problem, if it stays on the same side its something external.
