07-29-2014, 09:59 AM | #2 |
Rep 1,254
If this sounds like clicking when turning check your lug torque. I had this issue on my 135i and dealer recommended torque at 90 -95lbs. It resolved the issue right away. Anytime i swapped wheels for winter and summer I would forget and torque at 89lbs but once i heard the click noise again I just re-torqued to 90-91 and it went away.
07-29-2014, 11:01 PM | #4 | |
Rep 44
But i think this is a problem with the front brake. When i brake while the noise, does it end.... |
07-30-2014, 07:27 AM | #5 | |
Rep 1,254
The other thing is who knows if the torque wrench used is torquing perfectly at 89lbs. It could be off by a couple lbs this is why adding 2-4lbs will negate variance in the wrench. And from what the dealer told me on my 135i torquing a couple pounds higher then supposed recommendation is ok.
