01-19-2015, 07:24 PM | #23 |
Rep 6,673
Maybe it's the other way around? Maybe M135i/M235i just play a pre-recorded synthesized sound via the hi-fi speakers, which can be later coded to mimic the s55 engine noise? This does not mean they share the same " active sound" systems.
01-19-2015, 07:25 PM | #24 |
Rep 6,694
If you read the thread, you can code to about 10 different engine sounds.
01-19-2015, 07:29 PM | #25 |
Rep 4,686
Drives: L'Orange
lol. what a joke.
i want my car to sound the way my car sounds......the end. the plot has been lost, apparently. i don't need microphones, active sound, modified sound, or whatever else is needed to infuse enthusiasm into these cars. The cars should be built with enough enthusiasm already! |
01-19-2015, 07:29 PM | #26 |
Rep 6,673
Exactly! If you can code one, you can code 50. But what I'm saying is, the mere fact that it can be coded on the M235i to mimic the sound of the F80, is not confirmation that the f80 uses the same augmented sound technique. It seems that the coding involves a bunch of pre-recorded audio files. Not sure if I'm explaining my point clear enough.
01-19-2015, 07:33 PM | #27 | |
Rep 6,694
You are explaining your point. |
01-19-2015, 07:42 PM | #28 | |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
This was the post that I was referring to and is written post production, not pre-production like the ones that you mention. http://f80.bimmerpost.com/forums/sho...76&postcount=1 In this post it says "Speaking of sound, I struggled initially with the idea of having any kind of ‘Active Sound’ in an M car. Through first hand conversation with Albert Biermann, head of BMW M, I confirmed that active sound operates on an algorithm with multiple parameters including: throttle position, engine speed and engine load. From these values, the system calculates synthetic engine sounds to be projected into the cabin to accompany the mechanical soundtrack. Albert said that the intention was to provide greater engine speed feedback to the driver to compensate for the more muffled sound of the turbo engine."
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
01-19-2015, 09:00 PM | #29 | |
Advocatus Douchebagus. Sex Marxist.
2415
Rep 3,415
Drives: Lucy.
In the response from Albert to Sam on a question (from me, actually) to clarify the AS (which quote is contained in both of those links in my post) there is essentially the exact quote SakhirM4 has used in this thread. I don't know if that is necessarily different from the other quotes above but it is where that comment comes from at least.
Drivin' Lucy
01-19-2015, 09:04 PM | #30 | ||
General
21117
Rep 20,741
Drives: 2021 911 turbo
Difficult to get the truth between all that marketing |
01-21-2015, 08:00 AM | #33 | |
Rep 6,299
01-23-2015, 05:26 AM | #34 |
Down Under!!
1621
Rep 4,294
lol, ether way, its nice and synthetic, enjoy, and make sure your urine samples are ready for collection each and every night at 20:00 hours sharp. :P
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by |
01-23-2015, 08:31 AM | #35 |
Rep 439
"Critically, there will also be no artificial sound generation – the electronic noise (which BMW calls Active Sound) will instead simply be a real-time amplification of induction noises actually produced by the engine."
Uhm, conversion of mechanical sound to electronic sound (that is digitally signal processed and played through audio speakers) is artificial sound generation. Regardless, I feel for the auto manufacturers (not just BMW) that need to resort to this trickery. Consumers want muscular sounding cars, but can't get them because noise/emission/mileage regulations have neutered what manufacturers can offer. This is the future; get used to it. |
