2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning How much crank/whp am i putting down?
      01-02-2015, 03:15 PM   #1
rmshashaty
rmshashaty's Avatar
Drives: m235i
Until i can get to a dyno in the spring i am trying to figure out how much power i am putting down, please let me know if you state crank hp/tq or whp/Tq:
M235i
Jb4 stg2 (Map 2) (Have been using Map 5 with E40, so far no issues more power than Map 2, E30 with map 5 i had issues.)
Bms intake
ER DP
EWG wires
FF Wires
BMS charge pipes
Currently running E40 (FYI no issues, i started with E20)
      01-02-2015, 03:50 PM   #2
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
Same setup dynod 352/390 on a 89 deg F day.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      01-02-2015, 04:17 PM   #3
rmshashaty
rmshashaty's Avatar
Drives: m235i
And this was with running e40? I was hoping to make more than that with e40...
      01-02-2015, 05:06 PM   #4
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
One user that dyno'd after FBO and map 6 was running 400/450. A few different bits, and an intercooler, but other than that, about the same... except for the jb map that was used.
      01-05-2015, 12:32 AM   #5
eboosted
Peru
31
Drives: x6 5.0i xdrive 2009
What issues did you had on map 5? It is supposed to autotune and pull timing and boost as needed in order to avoid problems. Have you made logs on that map?
      01-05-2015, 11:29 AM   #6
rmshashaty
rmshashaty's Avatar
Drives: m235i
It would hesitate and bog when using map 5 with e30 or less on wot at times. But with e40 it is running solid on map 5. Burger does state on EWG cars they do not recommend running e85 on anything higher than map 2.
      01-14-2015, 07:54 AM   #7
ShlemonboostedM
ShlemonboostedM's Avatar
92
Drives: 335i F30
All depends on the dyno .. Theirs people 235i fbo dyno 426whp with same mods too but on some weird hub dyno .. Anyway numbers will always be different with everyone .. At least if everyone use dyno jet difference will still be their but shouldn't be more then 10whp or so ...
Search this Thread:
