08-30-2016, 01:00 PM | #23 | |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
Trying to argue with someone that has had both Dinan and many other tunes is interesting approach considering you've never done anything but Dinan... |
Jadar1752.50 |
08-30-2016, 01:18 PM | #25 |
Rep 25
After another day of research, I think I have a better understanding now.
As it looks like the majority of the stage 1 product is doing boost increase across all RPM, but the model like JB4 that connected to addition module is capable to control boost by RPM and other factor as well. While I don't plan on adding anything else other than the Plug-in Mod. It seems to me that the JB4 might be a little safer. I am basing my experience on the used 06 STi that was Protuned with a Cobb AccessPort where Boost can't be added across the full RPM Range with in a fix amount. So, if I am correct, I can keep everything stock and still use the JB4, right? One other question, it used to be that when I modify the tune myself on the Subaru myself, I would also make adjustment to the timing, and make sure the Air Fuel Ratio doesn't go to lean. Does any of that still apply to this Plug-in Solution? Or the BMW ECU is capable enough to compensate? |
08-30-2016, 01:21 PM | #26 | |
The Schwab
473
Rep 1,605
The ECU is capable enough to compensate, but you can always run logs off the JB4 and then adjust if anything is off. |
08-30-2016, 01:29 PM | #27 | |
Rep 439
2016 ///M235ix | MP Grilles | MP Pedals | Gloss Black M235i Badge | Dinan CAI | Dinan tune | Dinmann CF Diffuser | MP CF Spoiler | CF mirrors | M2 CF interior | M2 Steering wheel
08-30-2016, 01:40 PM | #28 | ||
Rep 893
Flash > JB4 > other piggybacks > Dinan
2019 SG M5C
crbalch472.50 |
08-30-2016, 01:51 PM | #29 | |
Rep 25
I plan to stay conservative. My previously owned 06 STi used to make 267HP / 277TQ on a mustang Dyno. It was a conservative/safe tune, and I love it. I don't need a monster, just want to unlock some power on the N55, one of the reason I go with a M235i over a M240i. Thank you guys =D |
crbalch472.50 |
08-30-2016, 01:58 PM | #30 | |
The Schwab
473
Rep 1,605
Reputable - the Dinan sport just came out, sorry but you can't build a reputation on a product that got released a few weeks ago. You can build it on other products, which have been proven to fail and not get honored... Factory warranty - you argue the Stage 1 plus, but you unfortunately couldn't afford that so you are stuck with no warranty as well. Also just remembered you're the kid that has the sweet vanity plates, definitely going to trust your judgement when it comes to this stuff... |
Jadar1752.50 |
08-30-2016, 02:00 PM | #31 | |
The Schwab
473
Rep 1,605
If no ECU flash, JB4 is definitely your best bet. |
08-30-2016, 02:10 PM | #32 |
Rep 447
Back to the original poster and topic. If you aren't going to add any other mods or use E85 mixes, don't waste your time and extra $$ with the JB4. It does not adjust boost by RPM unless you are running custom map. For a stock car it is recommended by BMS themselves that your run map 1 which is identical to stage 1 BMS in terms of power and also that added power is the same on map 1 across the RPM range; about 4 psi of extra boost constant. 2 plugs solution = JB stage 1 or Dinan Sport. Dinan Sport does not give you any car warranty for issues, don't be fooled by what you may have read regarding car warranty and Dinan, as this only relates to their $2k plus tunes, not the $300 option we are talking about here.
If you want a simple plug in tune that comes with a stock RPM based setup then AA8 or RaceChip Ultimate with Bluetooth connection are your easiest pre-set options. JB4 is designed for cars with supporting mods which it sounds like you won't be doing any.
08-30-2016, 02:21 PM | #33 | ||
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Dinans reputation? Are you kidding me? You're like this 14th person on this forum thats right 14th because their sales on here's shit, (they're lucky to sell 2 dozen dinatronics) that is arguing the same point based off of warranty retention because backed into a corner you have no valid point or intellectual tuning experience vs EVERYONE else and every single time you (Dinan) guys say well I have a warranty and you don't. No you're dead wrong in modded to the teeth and I still have my warranty. Dinan left by the way. You're so stuck on e36 and 1996 get a clue. Dinan refuses warranty claims and you're to thick to even ask why or who did that happen to because you're so stuck on justifying your purchase. Fine your money whatever spend it how you see fit. but you clearly have no idea all your comments show it. But yeah we all on here have zero clue and our mods are cheap shit.
FBO-PS1 and stuff
08-30-2016, 02:22 PM | #34 | |
Rep 439
Factory warranty, Dinan offers it yours doesn't. Funny how someone going the cheap route states someone cant afford something lol. I live very comfortable with no mortgage. try another angle, but the cant afford something while yourself being cheap isn't working very well. As long as you're happy with your cheap tune, I'm happy for ya!
08-30-2016, 02:24 PM | #35 | |
Rep 439
08-30-2016, 02:26 PM | #36 | ||
Dejan
1753
Rep 4,197
But yeah none of us know anything and use junk. You bought junk that's copied. Dinan talked so much shit about piggy backs on the E platform and said repeatedly how JN4 is shit and they'd never put a piggy back on their cars and yet since they're clueless and can't tune cars for shit here we find ourselves on the F platform with Dinan using a piggy back and their answer is "well we feel right now this is the best solution moving forward." Yeah who's the biggest hypocrite in that case you or Dinan. Or do you even know anything about this "well reputable" company you're so valiantly supporting.
FBO-PS1 and stuff
08-30-2016, 02:27 PM | #37 | ||
Dejan
1753
Rep 4,197
And search Dinan won't cover or vouch for warranty and you'll be so glad you chose them..
FBO-PS1 and stuff
08-30-2016, 02:28 PM | #38 | |
The Schwab
473
Rep 1,605
Also, not gonna entertain the little Dinan guy anymore, hopefully he goes away. OP should have what he needs at this point. |
08-30-2016, 02:32 PM | #40 |
Rep 439
I'll stick with a company backing a factory like warranty and IF you're not putting in all sorts of cheap mods of downpipes ect, then they will cover it. jb4 will tell you to go blank yourself.
08-30-2016, 02:40 PM | #41 | |
Dejan
1753
Rep 4,197
Let us know how it works out on your sport tune that's not covered and your charge pipe failure because they blow under factory boost. Well eagerly await for you with friendliness and open arms just like the other ex Dinanites
FBO-PS1 and stuff
08-30-2016, 02:50 PM | #42 |
Rep 439
LOL!! you're joking right?? jb4 or anyone of the numerous cheap junk mods people buy for their car here are far more likely to run into a failure. I'm 100% confident in Dinan products. That's why I wouldn't put jb4 on my car for free from the worry of some cheaply made product that has problem after problem. You don't like Dinan, I don't give a rats behind. Enjoy your cheap jb4 crap product and have a nice day.
08-30-2016, 02:50 PM | #43 |
Rep 5,369
Are you dense? The Dinan device on your car is only warrantied for the device and not one ounce of damage that it may cause to your motor. Dinan products have caused issues and had tuning issues just like any other piggyback device out there. You really should move along and go back to your 3rd grade class. Recess is over.
08-30-2016, 02:51 PM | #44 | |
Dejan
1753
Rep 4,197
Have a great day sir enjoy your car M235 is a wonderful machine.
FBO-PS1 and stuff
crbalch472.50 |
