08-25-2016, 07:15 PM | #1 |
Rep 62
Sputtering/Loss of Power/Hesitation when shifting
I recently installed BMS Stage 1 and a BMS intake. When I get on the throttle and shift into the next gear, the car losses power and I have to back off the throttle. It also sometimes sputters a few times and then gets back on the power after a couple seconds. I'm thinking it has something to do with the intake, but I'm open to suggestions.
08-25-2016, 07:44 PM | #2 |
Lucky13
211
Rep 1,762
Possibly a coil, I only say that because our 335 convertible has had this happen twice and it was coils both times. My N54 did it both time with 40-50,000 miles so its doubtful you have the same issue but you have the same symptoms.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
08-25-2016, 09:06 PM | #4 |
Rep 62
Ya i have 23000 miles with no codes.I just checked all the fitments. Nothing was loose on the intake connection. I'm planning on taking it off this weekend and doing some pulls.
08-25-2016, 11:24 PM | #5 |
Rep 356
Drives: 2014 m235i
I'm having the same issue I have jb4 and bms intake. I was thinking coil pack or spark plug. Not getting codes though, so I've been waiting to get codes to diagnose. It doesn't happen all the time but is very annoying when it does. My 335 did this too but threw a code right away so it was easy to figure out the problem.
Subscribed to see other people's opinions |
08-26-2016, 10:03 AM | #6 |
1006
Rep 1,653
There is a nipple on the intake with a little rubber cap on it. Make sure this rubber cap is tightly fasted to the intake. It seems that when the engine bay gets hot, that rubber cap expands, allowing air to escape which causes issues. This happened with my car and I zip tied that rubber hose onto the nipple and haven't had any issues since.
You also may just have a bad intake. These BMS intakes have seem to be hit or miss with our cars. Probably just better off taking the intake off and seeing how the car reacts. |
N55guy214.00 |
08-28-2016, 02:31 PM | #7 |
Rep 62
Took intake off, and the issue is completely gone. I may try to reinstall and secure that rubber cap better as Fabspeed mentioned.
Fabspeed Motorsport1005.50 |
08-30-2016, 10:28 PM | #8 | |
Rep 356
Drives: 2014 m235i
09-04-2016, 11:40 AM | #9 |
Dream crusher
984
Rep 2,421
Also and this a shot in the dark without knowing some more data, but the maf could be affected and need to be told CFM has increased and tune doesn't know what to do when maxed out or just plain 'Ol cleaning of the maf.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
09-11-2016, 11:00 PM | #10 | |
Rep 356
Drives: 2014 m235i
03-07-2020, 10:31 PM | #11 | ||
Rep 2
