08-25-2016, 12:40 PM | #1 |
Rep 1,541
JB4 and exhaust flap issue.
Not getting a response on the other boards so I'll try on 2addicts.
JB4 and exhaust flap issue... Been running fully open, but I just put on my MP exhaust so I wanted to try to go back to OEM mode to test the sound. Basically even with the JB4 set to OEM operation (both blinkers) the flap stays open even in comfort mode. I can force it closed using the JB4 close option, but when I put the JB4 back to OEM mode it will open the flap again (in comfort mode) after 30 seconds or so and stays like that no matter what driving mode I'm in. Anyone else seen this? Is there a way to "reset" the jb4 to go back to it's original settings?
08-25-2016, 03:28 PM | #2 |
Rep 201
Drives: 2017 GT350
Hmmm. I had a JB4 and I also had a canflap before that. I just left them open all the time. If you have OEM operation selected, it should just do "what it does". The only time I could note any difference was when I'm in my garage and you can hear the "clink" noise of it operating. On the road, I could never tell
08-25-2016, 04:05 PM | #3 | |
Rep 1,541
Same issue this guy is having: http://f80.bimmerpost.com/forums/sho....php?t=1129390
08-25-2016, 04:33 PM | #4 | |
Rep 190,687
Anthony235715.00 |
08-26-2016, 10:01 AM | #5 | |
Rep 1,541
That would mean the flap is only there to be closed during warmup? I find that hard to believe. Also even then it means my flap is not working correctly when Jb4 is in OEM mode. My flap is open 24/7 (which the ladies do like )
08-26-2016, 12:16 PM | #6 | |
Rep 190,687
Anthony235715.00 |
08-26-2016, 12:31 PM | #7 |
Rep 1,541
Interesting. Can someone with a stock 235 confirm?
08-27-2016, 09:21 PM | #9 |
Rep 201
Drives: 2017 GT350
08-27-2016, 10:35 PM | #10 |
Rep 304
08-28-2016, 09:48 AM | #11 |
Rep 304
I forgot to double check after starting the car up but came back home and noticed it was closed under comfort mode and open on sport mode, even switched modes several times to verify.
08-28-2016, 05:51 PM | #12 | |
Rep 1,541
Anyway to do a factory "reset" on the jb4?? |
08-31-2016, 10:00 AM | #13 | |
3441
Rep 79,212
http://www.n54tech.com/forums/showpo...33&postcount=1 |
08-31-2016, 10:19 AM | #14 | |
Rep 1,541
I'll try and pull the negative battery terminal. See if it resets anything.
