2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning P0420 Code with a catless dp
      11-21-2014, 06:15 PM   #1
TB///M3
Drives: 16 ///M3
Anyone get a P0420 Fault code with a catless downpipe?
I do have a Stage2 JB4 and thought it auto clears that.
      11-22-2014, 12:45 AM   #2
r33_RGSport
General
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Is this the first time it shows up since you install the JB4?
How did you get that code, from the JB4 via USB and JB4 desktop software or OBDII diagnostic tool?
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      11-22-2014, 07:59 AM   #3
TB///M3
Drives: 16 ///M3
This is the first time seeing this code after the dp pipe install.
I got an engine light and saw the code on the P3 vent gauge, apparently, it cannot clear that code.
      11-22-2014, 11:13 PM   #4
ShlemonboostedM
ShlemonboostedM's Avatar
92
Drives: 335i F30
P3 gauge intafear with jb4 probably that's what made this code .. As I heard that p3 gauge and ib4 fight for can bus even make your car run Weird .. U can't have p3 gauge and jb4 together .. Wanted to run that setup as Terry told me that he don't recommend this .. Sell ur gauge ..
      11-23-2014, 12:21 AM   #5
r33_RGSport
General
@BluF22, try unplug the P3 from the OBDII and see if the JB4 will clear it out.
      11-24-2014, 02:28 PM   #6
TB///M3
Drives: 16 ///M3
Thanks for all the suggestions, well, I tried clearing it in config thru P3 gauge multiple times and it didn't clear the code. I was on JB4 map 5 for custom tune, i switch to map 2. Drove for couple of miles and the engine light went away. Not if switching the map actually cleared it, but it's gone now.
      11-25-2014, 02:47 AM   #7
Cateye
Drives: M135i
Hi,
I have a different code with Catted dp
P013A shown on P3 gauge.
Just like your case, i cant clear away.
I am on JB4 map 5.
It seems that you could clear away after switching to map2.
Maybe you would like to switch to map 5 and see if the code appears again.
cheers
Miguel
