10-31-2020, 07:33 AM | #24 |
Rep 528
DOH you are right, the tires are Continental DWS 06, 205/50/17
Understeer is not often a problem on dry pavement. The car corners like it is on rails and unless I get into trouble I won't be worrying about it there. It is on wet or icy or dusty pavement, and on dirt that it is annoying. Yes applying a touch of braking or a moment of excess steering input should make a RWD car get a little tail happy. But this car just plows. A little excess throttle should do it but the nannies, even in sport mode, prevent it. |
10-31-2020, 08:09 AM | #25 | |
Rep 3,506
FWIW, my wife's Mazda 3 came with 215/45-18s all around.
10-31-2020, 08:23 AM | #26 |
Rep 6,069
Did you pick that narrow size because they stay on all year and you saw some prior threads about winter tires performing better when narrower than usual? I don’t know if any website that would suggest that size for a standard usage. How did you wind up with that?
10-31-2020, 02:02 PM | #28 | |
Rep 318
On icy or dusty pavement it is easy to turn the wheel farther than the traction available can handle, so the front wheels start to slide before the car can load the rears. That feels like understeer but I think there should be a different word for it.
18 M240i RWD auto
Previous: 01 Z06, 99 323i |
11-01-2020, 04:50 AM | #29 |
Rep 528
Those are the standard size that came on the car new. The contact patch is similar to lower profile tires on larger rims. (50, 60, etc is a ratio) 17" rims are best for rough streets. A bigger contact area is not a good thing on wet or snowy roads. These are good tires for a DD.
11-01-2020, 09:29 AM | #30 | |
Rep 6,069
11-01-2020, 10:00 AM | #31 | |
3708
Rep 3,621
11-03-2020, 06:55 AM | #32 |
Rep 2,878
FWIW, contrary to the marketing hype (and about 3/4 of the posts on here) the contact patch SIZE is always the same (at the same pressure and car weight) regardless of whether it is a 205 or a 255 - it just gets longer and narrower on a narrow tire (best for heavy rain/snow). Wider tires don't put more rubber on the road, just on the wheel.
And if the problem only occurs on very wet or muddy roads, then it is natural physics, not a question of handling balance. This is like the poster case for why the automakers try to dial in just a touch of understeer, because it is soooo much better that you bitch about a little plowing that is easy to control, rather than joining the 'where can I find a good body shop' club. |
11-03-2020, 07:45 AM | #33 |
Rep 528
Hi Maynard
Interesting idea 'same size patch'. Well it points out a trend in similar tires but at the extremes it wanders off. Tires are more than balloons. The sidewall carries some of the weight and the center of the tread carries some. So in very narrow tires the sidewalls carry more and on very wide tires the tread carries more. Still, the trend is instructive. 205/50/17 is about the same contact patch as 225/45/18 so these are not really narrow tires. I could go to 225/17 on the front but that would make understeer worse on wet, snowy, dusty pavement and tire rotation would be compromised. |
11-03-2020, 09:00 AM | #34 | |
Rep 3,506
I went to a remarkably comprehensive tire calculator page to find the contact patch sizes for the 245/35-18 that came on the rear of my car and the 205/50-17 tires that came on OP's car. The difference was 2.2%, or virtually nil for our purposes. The calculator is on this page: http://bndtechsource.ucoz.com/index/...alculator/0-20, and this is its input form: and these are its static and dynamic output forms:
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 11-03-2020 at 09:15 AM.. |
11-03-2020, 10:36 AM | #35 | |
Rep 2,878
dradernh4464.00 |
11-03-2020, 12:59 PM | #36 |
3708
Rep 3,621
The other thing to remember is that friction is proportional to friction coefficient and load, so for the same load and same rubber compound with the same mu, the friction (grip) will be the same. The tyre compound is much more important than the width - the width, profile and tread variations will just allow a softer compound to be used before destroying it.
Maynard3857.00 |
11-03-2020, 01:36 PM | #37 | |
Rep 318
For example, for the default sizes that come up on the web page, 245/45ZR17 vs 275/40ZR18 the wider tire has a 23% larger contact area. For the tires sizes on our cars, 225/40ZR18 and 245/35ZR18 I get an 18% larger contact area for the 245s. (That's using wheel sizes of 7.5 and 8, which I think are correct. The results are quite insensitive to wheel width. I used a load index number of 95. I couldn't find those numbers, but if they are the same then the actual number makes little difference.) I'm calling BS on this claim that tire width makes no difference to contact patch area.
18 M240i RWD auto
11-03-2020, 02:05 PM | #38 | |
Rep 318
If you change to tires with a larger contact patch (for example comparing the 225s and 245s that are available on our cars, which have an 18% difference in contact patch area according to the calculator provided by draderh) the weight per square inch of the contact patch should decrease exactly as much as the contact patch area increases, so the total friction generated by the contact patch should be the same. Practical experience indicates this is not true - otherwise there would be no reason to use wider tires. My hand-waving argument is that the law of friction applies to smooth surfaces, where only microscopic irregularities cause friction. Road surfaces have macroscopic irregularities that distort the contact area and it takes extra force to move the tire over those irregularities. Thus tires with a larger contact area can produce more friction since they cover more macroscopic irregularities. It would be great if someone could provide a better explanation of why we're not using bicycle tires on cars since by the basic theory of friction they should produce just as much cornering force.
18 M240i RWD auto
Previous: 01 Z06, 99 323i Last edited by albertw; 11-03-2020 at 08:41 PM.. |
Moflow2484.50 |
11-03-2020, 02:35 PM | #39 |
3708
Rep 3,621
I would take that tyre characteristics calculator with a grain of salt without being able to look at their input equations. If you put in the same parameters for wheel diameter, tyre load index and adjust the profile to give the same tyre diameter, then recalculate with the same tyre pressure and corner weight, it gives exactly the same contact patch length for a 205/50-18 tyre vs a 275/35-18 one. This goes against all tyre manufacturer information showing contact patch photos with different tyre width. The contact patch area is just a simple calculation of length x width in the application, this is unlikely to be true for any tyre.
It just doesn't pass any reasonable analysis as being accurate, but may overall give a general indication of trends. Most likely the equations used are very basic and not based on real-world materials values and characteristics or dynamic tyre properties. |
11-03-2020, 02:43 PM | #40 | |
Rep 1,602
Which is not to say other variables won't have as big of an effect, my POS Lemons race car went from "neutral" to "insane oversteer" when i swapped the front knuckles, slightly changing the front suspension geometry while leaving the tires completely untouched. |
11-03-2020, 03:05 PM | #41 | |
3708
Rep 3,621
My Caterham on 195/50-15 road tyres is faster for the first 8km of track distance (At Castrol Raceway in Edmonton, which you may well know, being in Alberta) than on the slicks that have an equivalent tread width as 205/50-13 front and 235/45-13 rear tyres. The RE71-R road tyres hit the optimum temperature for their rubber after about 5km, then give consistent grip for the next 10km or so before getting greasy due to overheating and loosing grip again. The Hoosier slicks take about 10km to get to their optimum grip, but if I have to slow down under a yellow flag, then they have less grip than the road tyres after 1km or so due to being too cool. Those I know in the UK with Caterhams find that too wide a tyre gives no more grip for the same compound, but takes longer to hit optimum temps. For any given car there will be a point where you can't keep the rubber at the optimum temp for the conditions it is used in and the width of tyre in use. Wider isn't necessarily better for reaching and staying at that optimum point. |
11-03-2020, 03:17 PM | #42 | |
Rep 400
245 vs 205 tire, contact patch area difference is only 2%. (compare to ~20% tire width difference) |
11-03-2020, 03:42 PM | #44 |
3708
Rep 3,621
Just another thought on bicycle tyres. My road bike with 22mm wide tyres at 8.5bar / 125PSI can corner on asphalt better than a fat bike with 140mm/5.5" wide tyres at 0.4bar / 6PSI, considering the fat bike tyre has a much larger contact patch of about 225 sqcm compared with 11sqcm for the road bike.
