11-30-2022, 07:11 AM | #1 |
Rep 59
Drives: BMW 220D F22, Mazda MX5 ND
Millway camber plates with ST Coilovers NVH Problem
Hello all,
I bought Millway street camber plates last week and installed it to my 220D with ST Coilovers. After the installation, everything looked great but I had excessive noise from the top mount. With OE top mount, there is no sound at all, but this plates made too much noise on the road. I guess it is because of the gap between shock's head and bolt nut. Attached Youtube video shows the noise on the road and the gap. https://youtube.com/shorts/0u90mx1AUTg?feature=share I mailed to Millway and the place I bought it (ML Performance) and waiting for them to provide a solution. But I would like to hear your opinions! Especially if there is someone installed Millway plates to ST coilovers. Thanks in advance |
11-30-2022, 11:05 AM | #2 |
3718
Rep 3,626
Driving the car without the damper/shock piston rod firmly torqued to the mount bearing is not really advisable, just causing wear between the bearing and piston shaft. This sounds more like an issue with the coilovers having a longer relief on the end of the piston below the thread than the OEM dampers. A spacer under the nut or temporarily several washers would be needed to allow the nut to be torqued correctly.
11-30-2022, 03:29 PM | #3 | |
Rep 59
Because we tried to put washers after docking the plate and torqued the nut on that did not help at all :/ Edit: when we install the OE top mount without any washers to the same coilovers, there is no problem. |
11-30-2022, 11:29 PM | #4 | |
3718
Rep 3,626
12-01-2022, 02:59 AM | #5 | ||
Rep 59
12-09-2022, 03:15 PM | #6 |
Rep 294
Drives: 2019 M240i Coupe RWD
My car has this exact same noise issue with the stock struts. Also running Millway Street camber plates. Let me know if you solve it!
12-19-2022, 03:47 PM | #7 | |
Rep 59
I am running with stock top mount for now. I will let you know if i fix this! Did you talk with Millway about that? Because they claim that i should not make any sound with stock struts. |
12-27-2022, 01:07 PM | #8 | |
Supreme Allied Commander
3887
Rep 54,534
Drives: F80 M3
Add a spacer or washer. |
12-31-2022, 06:06 PM | #9 | |
Rep 59
I'm thinking it might be the coilover making noise, not the plate. Because OE top mounts seems very sound absorbing, i dont hear any noise with them. This is why, we will test it on a friend's M235i with Öhlins coilovers and see if it make that noise. Photo attached to show the different between OE strut and ST coilover (ST on right) |
12-31-2022, 07:13 PM | #10 | |
3887
Rep 54,534
Drives: F80 M3
omerakz11.00 |
01-10-2023, 02:08 AM | #11 |
Rep 59
01-10-2023, 06:58 PM | #12 |
3887
Rep 54,534
Drives: F80 M3
01-10-2023, 08:44 PM | #14 |
3887
Rep 54,534
Drives: F80 M3
Looks like KW /ST for F8x chassis has a square shoulder so you are good to go!
Tags |
camber plates, millway, noise, nvh, problem, st coilovers |
