11-14-2015, 11:53 AM | #1 |
Rep 292
Drives: 2015 M3 6MT Matte Indigo Blue
Extremely Rough Idle after Dinan S2 Install
Hi everyone, I've been looking everywhere for an answer on this and I can't seem to find anyone that has had a similar problem.. After installing a Dinan Stage 2 piggyback (used) in my car, the car idles extremely rough and sounds like its misfiring. I've double checked all connections and verified that the software is correct (M235i, S2, Electronic Wastegate). I'm going to try to use the BT app today to see if that brings any new info to light. The good news is plugging the stock connections back into their stock location restores the car to 100%, no issues whatsoever. Any recommendations are greatly appreciated!
11-14-2015, 03:28 PM | #3 |
Rep 292
11-14-2015, 03:42 PM | #4 |
Rep 2
I intalled S2 and Dinan CAI two weeks ago. The first 4 days had really rough idle at cold engine startups. Revs went higher and lower than normal than with the S1 + factory intake. Almost felt the engine was going to shut down before revving up again.
Everything went back to normal idle/engine statup about five days after install, just after long drive with the car. I contacted my BMW service center / Dinan about the issue, still waiting for their response. Hope this helps. |
11-14-2015, 03:44 PM | #5 | |
Rep 292
11-14-2015, 04:15 PM | #6 |
Rep 2
My issue was just unusual revving up and down for a few seconds before idling, during cold startups. No misfiring. Now everything "feels" OK. Maybe the ECU adjusted itself tho the S2.
Do you notice any power difference, specifically above 2500-3000rpm during normal driving? Just waiting for the BMW/Dinan dealer response to see if Dinan has adressed the original issue in some way. Also waiting for the ios app. |
11-14-2015, 06:41 PM | #7 | |
Rep 292
11-14-2015, 07:23 PM | #8 |
Rep 292
Just plugged it back in and started it up, still sounds the same. Against my better judgement I let it run, but it shut off after 30 seconds or so. Looks like i'll be taking it in to a shop Monday.
11-14-2015, 08:11 PM | #9 |
Rep 5,103
I guess there's no warranty for this since you bought it used...
11-14-2015, 08:55 PM | #10 |
Rep 5,262
11-14-2015, 09:06 PM | #11 | |
Rep 893
2019 SG M5C
11-14-2015, 09:51 PM | #12 |
Rep 292
I'll try taking it out tomorrow. As for the warranty I'm not trying to get it covered, just have a professional look at it. I'm convinced it's something stupid that I'm missing.
11-16-2015, 10:02 AM | #13 | |
Rep 3,128
11-16-2015, 01:13 PM | #14 | ||
Rep 57
Issue with AFE. I removed it and problem solved . I have a drop in filter in . I wanted the Dinan intake but got tired of waiting |
11-16-2015, 01:54 PM | #15 | |
BMW Lover
122
Rep 251
u still use the S2 just with a Drop in Filter ??? , how do u find it so far ?? and do u plan to have Dinan air intake ? |
11-16-2015, 01:54 PM | #16 | |
Rep 3,128
Intake is no longer back-ordered now though in case you wanted to hop back on that train. That revolving door of back orders finally got shored up about a month ago. Just saying... |
11-16-2015, 06:57 PM | #17 | ||
Rep 57
11-25-2015, 06:09 PM | #18 |
Rep 292
Finally took the BMS out today. Car ran better, but still not good enough to where I'd feel comfortable driving... Any other suggestions? I should also mention that I have a shiftek catless downpipe and AWE tuning exhaust, perhaps the CEL from that is causing issues?
11-25-2015, 08:18 PM | #19 | |
Rep 893
2019 SG M5C
11-25-2015, 08:35 PM | #20 | |
Rep 3,128
11-25-2015, 11:46 PM | #21 |
Rep 292
11-26-2015, 12:14 AM | #22 |
Rep 3,128
Confirmed for m235i although that box has early firmware. There's been a few updates since the 1.44 version that has been on that box but I don't recall exactly what issue the updates fixed offhand so the updates may be meaningless. If you have access to a code scanner I would scan the vehicle to see what faults are shown since if it's running like crap I would be amazed if there weren't codes pointing you somewhere.
