2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Who has upgraded their clutch?
      01-08-2017, 10:33 AM   #1
zengoski
Drives: 2015 BMW M235i ALPINE WHITE
What clutch have you upgraded too and what are your mods?
jpnh1423.50
      01-08-2017, 08:52 PM   #2
JQuach07
Drives: m235i Alpine White
I will let you know soon. I have Spec stage 2+ clutch that's about to get installed. Current mod are FBO with PS2. About to drop in Enzo Big turbo kit the same time I get clutch installed.
      01-08-2017, 09:07 PM   #3
zengoski
Where did you get that clutch from? I cant find anything for our 2 series.
      01-10-2017, 04:30 PM   #4
JQuach07
You have to email the company. Spec or clutch master. They both have 2 different version one with oem flywheel or with aluminum. I know protuning freak has a dual clutch set up for a good price.
      01-10-2017, 04:33 PM   #5
jpnh
jpnh's Avatar
1424
Drives: NA
If you're going to do a new clutch then get rid of the DMF
You will get slightly more noise but gain durability/reliability
      01-11-2017, 09:54 AM   #6
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Upgrade to B58 clutch [same parts as F series 550i].
Could look at using dual plate clutch used on M2 ??
Current '22 X3M LCI..
      01-11-2017, 10:34 AM   #7
zengoski
hey are you sure about that? I orderd the 550i clutch and thought i made a mistake and was going to return it..
      01-11-2017, 11:02 AM   #8
jpnh
jpnh's Avatar
1424
Drives: NA
The M2 uses a dual clutch plate?
Do you know if it also uses a DMF?
      01-11-2017, 12:10 PM   #9
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Twin plate clutch - yes - part no 21212284234 - shared with other F8x MT cars
http://www.realoem.com/bmw/enUS/part...&q=21212284234
DMF - yes - part no 21212283028 - shared with other F8x MT cars
http://www.realoem.com/bmw/enUS/part...&q=21212283028
http://www.realoem.com/bmw/enUS/show...diagId=21_0270
jpnh1423.50
      01-14-2020, 08:20 AM   #10
designatedposter
Drives: m235i
did you finish install? what clutch and flywheel did you end up with?
      01-14-2020, 08:21 AM   #11
designatedposter
Drives: m235i
did you follow through? what flywheel did you use?
      01-14-2020, 06:53 PM   #12
Not a twin plate (or twin disc) clutch.. It's a dual mass flywheel with single sprung disc as per every other MT BMW we've seen in the last decade.
Here's the kit listed in your link by part # for clutch kit: https://www.ecstuning.com/b-genuine-...s/21212284234/
Although, a factory twin disc (manual not dual clutch auto) would be fantastic as a standard.
      01-16-2020, 02:49 PM   #13
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Sold a few Spec 2+ for the M235i 335i and 435i. It's a good clutch for typical FBO and even upgraded turbos.
