12-10-2016, 01:42 PM | #45 | |
Rep 716
Drives: F90 M5
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
12-11-2016, 10:52 AM | #46 |
Old Member
56
Rep 94
A warranty replacement part assumes the warranty of the part it replaced. So, if you had a 12,000 warranty and the motor gets replaced at 11,000 miles, that new motor only has 1,000 miles of warranty on it.
12-11-2016, 10:59 AM | #47 |
Rep 5,577
Are you sure, I thought a warrantied part was backed for one year?
12-11-2016, 03:28 PM | #48 |
Rep 3,395
Anthony235715.00 |
12-22-2016, 09:15 PM | #49 |
Car Enthusiast
282
Rep 501
Interesting to see that it was an oil pump.
Ive seen a fair bit of N55 engines blow here at the dealer.. Most are poor maint or chain issues...And on the XDrive vehicles Front driveshafts blow apart and cause a ton of damage - can either take out an engine or a transmission depending which end blows up. Funny enough.. 2 Weeks ago i did a PDI on a brand new M4... walked outside started the car up...walked back into the shop to put some paper work away....walked back out..car was no longer running and would not turn over... Found out a timing chain had jumped a tooth - bmw sent us a brand new engine. |
12-22-2016, 09:17 PM | #50 | |
Rep 3,395
As I understant it they're in the 440(?) M240 and at least one other car |
12-22-2016, 09:21 PM | #51 | |
Car Enthusiast
282
Rep 501
From a technician stand point...that Engine is going to suck lol - Mainly because it's based off the diesel engines...and well BMW Diesel engines are virtually indestructible. From a consumer/customer stand point - that engine is going to be extremely good in just about every aspect Power/emissions/fuel consumption etc. Will be interesting to see as time goes on. |
jpnh1423.50 |
12-22-2016, 09:32 PM | #52 |
Rep 716
Drives: F90 M5
UPDATE!!: so i just got the car back and everything is looking and sounding great, so i was reading the diagnostic report thing, and it says that the cause was " the crankshaft bearings came apart"
so long story short i got the car back and am breaking it in, and very eager to get back to modding it soon
B_Rice218.00 |
12-22-2016, 09:33 PM | #53 |
Rep 716
Drives: F90 M5
also for the break in period, would it make a difference if i put the BMS intake on it now or after the break in?
12-22-2016, 09:36 PM | #54 |
Car Enthusiast
282
Rep 501
12-22-2016, 09:37 PM | #55 | |
Rep 716
Drives: F90 M5
hahahahhaha yea when he said that the first thing i thought of was my friends E60 and yea im super excited right now
12-23-2016, 08:48 AM | #56 | |
Rep 1,753
12-23-2016, 09:05 AM | #57 | |
Rep 5,577
12-23-2016, 09:42 AM | #58 |
3441
Rep 79,212
Actually, when breaking in a new engine it is ill advised to limp it around at low RPM.
You should vary RPM and pedal input quite frequently. There should be information in your manual of the proper break in procedure. Most say something similar to what I said above. Honestly, I bought my BMW with 1.3 miles and by mile 15 I put it to the floor and all the way to red line. Car didn't skip a beat. However, since cars off the assembly line go through tests before leaving the factory, they are pretty much broken in anyway. An engine off the crate does need some time to seat the rings and get some heat cycles in the engine. Taking it easy and under 3000 wouldn't be my recommendation but flogging it out the gate wouldn't be it either in this case. Meet somewhere in the middle for the first 100 or so miles. 1200 miles would be an excessive an unnecessary break in time. That motor by mile 100 has gone 10's of thousands of revolutions already. |
12-27-2016, 10:49 AM | #59 | |
Rep 1,541
Just like e92 m3 without the oil pump failure
12-27-2016, 02:17 PM | #60 | |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
12-29-2016, 04:38 AM | #61 | |
Rep 716
Drives: F90 M5
12-29-2016, 04:39 AM | #62 | ||
Rep 716
Drives: F90 M5
01-05-2017, 11:48 PM | #63 |
Rep 716
Drives: F90 M5
So latest update. I reinstalled my BMS intake and it threw a code. Any ideas why?
01-09-2017, 10:10 PM | #64 |
Rep 356
Drives: 2014 m235i
Those intakes just throw codes sometimes... mine never did but I'm thinking my JB4 was suppressing the code like it does for the downpipe. I've seen a few threads on here where it's been mentioned
01-09-2017, 10:12 PM | #65 | |
Rep 716
Drives: F90 M5
