03-24-2015, 10:25 AM | #23 |
Rep 4,516
Yes
http://web1.carparts-cat.com/default...D107004&12=130 25mm/1" drop suitable for passive and adaptive - H&R part #28896-3
Current '22 X3M LCI.. |
03-31-2015, 08:19 PM | #24 | |
Rep 665
03-31-2015, 09:27 PM | #25 |
Rep 845
Got my springs installed today along with an alignment (2.25 F&R camber, 3/32 toe rear, 0 front).
Overall, I like the springs. Looks great, and the ride is noticeably more stiff. Less secondary motions. I like them. One weird thing is my suspension people said that the springs are a great fit, but are a little short for the front struts, so you need to be careful that they don't pop out if you use a floor jack to get the car up to change a tire. Other than that, went smoothly. I'll post a more thorough review after doing some track time this weekend. |
04-01-2015, 12:19 AM | #26 |
Rep 2,710
Drives: MB E350 4MATIC Estate
I don't have personal experience but probably! I wish someone that has tried both H&R without the bump stops and Dinan with them would give a review.
04-01-2015, 02:34 PM | #27 |
561
Rep 1,340
Bilstein B8 shocks are great when paired with the H&R Sport Springs. The shortened shock body ensures the spring is correctly located and lends to a more predictable ride and sharper responses. If you have any questions about either just let me know!
04-01-2015, 02:52 PM | #28 |
Rep 845
Probably, but the adaptive suspension is actually really good on the track and very expensive. Really gives the car a Dr. Jekyl/Mr. Hyde personality (street/track). Not quite willing to do away with such an expensive component of the car...
04-09-2015, 02:40 PM | #30 |
Rep 28
Drives: Estoril Blue 2014 335i xdrive
Shocks (dampers in the UK) are what control the 'bounciness'. BMW traditionaly has a very stiff bump setting and a softer rebound setting. I prefer a softer initial "hit" and then the suspension controlled with a stiffer rebound.
If you change the sway bars, you can keep the same springs and get less roll (sway bars increase the effective spring rate while cornering or working the suspension ie railway tracks). H&R springs get crashy with stock shocks because the shocks are designed to work over a specific range of motion. The shorter springs means the shocks will reach their minimum length early. Cutting down the bump stops gives the springs more room to compress. I suspect that the Dinan bump stops are just shorter. On an aside, I used to have the problem of shorter springs "falling out" when the car was jacked up on an E36 race car. I used tie-wraps to hold them up and "in". The tie-wrap is just a loose loop to stop them from falling out as opposed to anchoring them tightly in place. Having just gotten my M235 last week, and with snow today, I am yet to take it on the track and thrash it. So I've only mapped out a mod path as part of future plans. I'll be keeping an eye on the forums for everyone's reviews.
2014 Estoril 335i xdrive 6sp: M Sport, m perf power/brakes/sound kit, AA8 400 hp/ 420 ft-lbs. 10/15mm spacers. Dinan 3/4" spring kit, Misc coding. Mud flaps.
Racing/tuning/teaching since 1997. Long list of clubs as Chief, classroom and in-car instructor. Last edited by Blackcross; 04-09-2015 at 02:42 PM.. Reason: added bit about tie-wraps. |
04-25-2015, 09:40 PM | #31 | |
Rep 665
"This additional kit includes tuned, progressive rate bump stops that maximize suspension travel on the lowered car for improved handling capabilities and ride quality when compared to just a spring set." The Dinan springs are $409 with the bump stops vs. $250 for the H&R's w/o bump stops. After hearing of the crashing I'm actually debating on getting the Dinans instead....even though it only lowers the car 0.5" in front (but 1.0" in the back). |
04-25-2015, 10:54 PM | #32 | ||
Rep 765
In my assessment, the OEM bumps stops are already fairly small, H&R probably assessed the likelihood of becoming an issue as very remote. But you could always buy the H&R springs and Dinan bump stop kit. Or just shave the OEM bumps stops. They are only pieces of foam to prevent metal on metal contact if the shocks ever fully compress. And with Dinan, do not forget that they will not warrantee the springs unless installed by an authorized dealer. My local dealership quoted about $1800 for the springs, stops, and install. I assume this would have included any necessary alignment. That comes out to about $1000 more than the installation and alignment of the H&R springs by a local reputable shop. Quote:
That said, the Dinan set drop is nearly the same as the H&R set. Having driven about 300 miles on those, w/o the bump stops from Dinan, I never 'crashed' and the ride was very controlled - much better than stock. I doubt that two major manufacturers would have created aftermarket setups that would essentially destroy the OEM struts over time.
04-29-2015, 04:19 PM | #33 |
Rep 171
I have had horrible experiences with springs and oem dampers. Never on a BMW since this is my first but my main complaint and something I am not willing to live with is bounciness even though I would love the 1" drop. I am always so hesitant messing with suspension.
Any feedback on the ride quality? Some mixed feelings in the thread Last edited by boost82; 04-29-2015 at 04:26 PM.. |
04-29-2015, 04:20 PM | #34 | |
Rep 171
04-29-2015, 04:42 PM | #35 | |
Rep 446
04-29-2015, 05:11 PM | #36 |
Rep 845
I'm at Chuckwalla this weekend. Where are you at?
04-29-2015, 08:58 PM | #37 |
Rep 446
04-29-2015, 09:19 PM | #38 |
Rep 171
Awesome. I have been going back and forth about a coilover kit as well. Just can't keep my money in my wallet it's terrible haha
04-29-2015, 10:57 PM | #39 |
Rep 446
Haha Yea I feel ya there! Coilovers are great if you are willing to spend the money. Just my opinion but H&R springs, some sway bars, and camber plates and you are good to go and tear up the track.
04-30-2015, 12:23 AM | #40 |
Rep 528
Not trying to thread jack but has anyone considered the Bilstein B14 setup as an alternative to just springs alone? Is it a viable alternative before creeping into the upper level price ranges of the KW/JRZ setups?
04-30-2015, 12:00 PM | #41 |
Rep 446
I've heard a few people asking about those as well but have yet to see anyone on here review them. Those don't plug into the adaptive suspension right?
04-30-2015, 08:30 PM | #42 | |
Rep 28
So they are effectively "theirs" and are not just rebranded. H&R, Eibach etc will all have designed their own for their specific goals and 'tastes' for want of a better word. If you want maximum awareness of your suspension mods, I would suggest asking each of these companies what their spring rates are: e.g. 450 lbs front and 600 lbs rear? Or 500 lbs front and 500 lbs rear? That sort of thing.
Racing/tuning/teaching since 1997. Long list of clubs as Chief, classroom and in-car instructor. |
05-02-2015, 09:43 PM | #43 |
Rep 446
Quick update: Had my autocross session today and the springs did well! I wasn't expecting a huge difference of course and the improvements were subtle. A bit more composure and less body roll but I can't wait to get some new sways installed!
05-02-2015, 10:10 PM | #44 |
Rep 1,503
Hey you must be the guy that my friends texted me about! They were mad at me saying I went to Autoclub without telling them haha
